Is it possible to get small help with /etc/default/grub?
Hello all
I recently added lts kernel to my system as a fallback if the current kernel doesn’t play well with my system.
I am trying to get grub to remember my selection of kernel (boot the regular linux kernel), but so far not successful.
There is a section bit far in the grub file that says
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT=true
Which I have uncommented (as you can see), I have also changed GRUB_DEFAULT=0 to GRUB_DEFAULT=saved as mentioned in the section.
I did run
after my changes.
However, my system always boots lts kernel. I haven’t been able to find anything concrete about this on the arch wiki https://wiki.archlinux.org/title/GRUB#Detecting_other_operating_systems
Am I missing anything?
Really stupid question - You have removed the “#” character at the beginning of the line?
If you changed the file and regenerated grub.cfg while booted into linux-lts, that is what it remembers.
I was in the rolling kernel when I generated the grub.cfg (I am almost 100% sure of that)
Will try it again though.
Yes, like I said, I have uncommented the line.
Hi @olividir
If I may comment, I learned here that it is better to use LTS as it is more stable and more tested. Unless you need the default for a specific reason.
Though I am on EndeavourOS as a rolling release, and this is just one of the reasons I like it, I prefer stability and reliability.
If LTS works fine with you and give you what you need, better stick to it.
Thanks for the advice. I am running quite new hardware which could get better benefits of newer kernel, which is why I tend to be on the newer kernel :slight_smile:
Wouldn’t GRUB_DEFAULT=0 alone be sufficient for the kernel with highest version to be first on the Grub boot menu?
You could then just adjust GRUB_TIMEOUT= to time (in seconds) to your liking.
Sorry @limotux, the reply was meant for @olividir.
Neither
GRUB_DEFAULT=0 or GRUB_DEFAULT=true is giving me the boot of running kernel.
I have noticed some weird errors at the beginning of boots after installing lts-kernel.
      Booting 'EndeavourOS, on linux-lts'
error: sparse file not allowed.
Loading kernel linux-lts ...
Loading initial ramdisk ...
Press any key to continue...
This is very new to me… at this time I either wait for 15 - 30 sec or press any key to continue… which is not ideal.
With your current settings, could you post the output of:
cat /etc/default/grub
Also:
cat /boot/grub/grub.cfg | eos-sendlog and post the URL
You can’t use save default with btrfs.
Grub only supports reading btrfs. It can’t write so it can’t save the setting.
Aaaahhhh
That is a solution :smiley: :rofl:
So that was it: BTRFS!
:blush:
How about I make a new post for the boot error??
That is the reason for the boot error.
Disable save default and it will go away.
I would revert the changes in the /etc/default/grub and regenerate grub.cfg first.
Reboot and see if you still have that error.
You are correct, reverting the changes fixed that error.
Now to see if there is a bootloader that can handle two kernels, remember which kernel I want and works with BTRFS :laughing:
Why sorry! It is OK with me and hope it is OK with @olividir
He had the answer anyway.
You are welcome.
Yes, sometimes you may need the latest kernel for the latest hardware.
becasue I use btrfs too, I tried it on my system, with the same behavior.
But I prefer btrfs with snapper than switching to ext4 only for such a little annoyance.
how is this with systemd-boot?
I tried systemd-boot, it does not detect snapshots unfortunately.
