Iriun webcam problem
So i installed iriun webcam, connected my phone to the internet that my pc is also connected to, but it just wont connect. I looked for other topics for this issue, but nobody made one. I’m looking if people had this same issue and resolved it, please help.
Welcome to the community! :vulcan_salute: :enos_flag:
Most people’s routers have 2.4 and 5.0 GHz connections for WiFi. Are you using WiFi or a direct cable connection for your computer/laptop?
Next thing is firewalls and VPNs: If you are using either one, they may interfere with Iriun or straight up block it. A VPN would possibly present as a different internet connection, so you’d have to turn that off or try to have the same exact VPN connection on both devices.
Lastly, I just tried to run it on my device, but it would not even open, and I got the following error when checking from a terminal.
iriunwebcam: error while loading shared libraries: libusbmuxd-2.0.so.6: cannot open shared object file: No such file or directory
Does the app actually launch on your computer, but fail to connect?
Or does it not launch at all?
I use WiFi, and somebody solved that iriun webcam wasnt launching so maybe that will be fixed , but iriun webcam didint work before. I just need it for the mic part, By the way, the command to fix it is this:
sudo ln -s /usr/lib/libusbmuxd-2.0.so.7 /usr/lib/libusbmuxd-2.0.so.6
Turning off the firewall does indeed work, but i thought the microphone would work in it, because my microphone right now sucks alot and i wanted a alternative option till i get a new one.
Thanks alot though!
