Hello I am new here i just ran into a issue my hard disk failed to mount it give me that message below
{An error occurred while accessing ‘New Volume’, the system responded: The requested operation has failed: Error mounting /dev/sda2 at /run/media/njm/New Volume: wrong fs type, bad option, bad superblock on /dev/sda2, missing codepage or helper program, or other error}
i have been trying to figure it out can anyone guide me on how to fix it thank you.
The result
njm@njm-z390aorusprowifi ~]$ sudo mount -t ntfs3 /dev/sda2 /mnt/drive1
mount: /mnt/drive1: wrong fs type, bad option, bad superblock on /dev/sda2, missing codepage or helper program, or other error.
dmesg(1) may have more information after failed mount system call.
If you install the ntfs-3g package there are some user space tools you can use to diagnose disk issues. Although it is better to use Windows to repair ntfs issues.
If your not sharing that particular drive with a Windows Install then why do you have it ntfs? If you are using that space only for Linux I would recommend a more native linux file system that natively supports Unix file permissions.
you can try ntfsfix --clear-dirty according to the Arch Wiki
As @dalto points out its best to use windows to fix problems with the NTFS. You can download Hirens Boot and use it instead of having to worry about installing Windows. Use its more native NTFS tools to fix your drive. If the above doesn’t work
