To help you with the entry you have to add to fstab we’ll need some information.
Please run the following commands in a terminal and post the results:
cat /etc/fstab | grep -v "#"
sudo blkid
sudo blkid
UUID=C83C-D4DC                            /boot/efi      vfat    umask=0077 0 2
UUID=7ceb18dc-8232-4529-bc7c-1d228df1fc35 /              ext4    defaults,noatime 0 1
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
/dev/sda1: UUID=“C83C-D4DC” BLOCK_SIZE=“512” TYPE=“vfat” PARTUUID=“8fe62bdb-4ba8-a545-b842-32494cdd1cd8”
/dev/sda2: UUID=“7ceb18dc-8232-4529-bc7c-1d228df1fc35” BLOCK_SIZE=“4096” TYPE=“ext4” PARTUUID=“5c31e520-6d92-aa4f-b87a-f7ee6dc49401”
/dev/sdb1: LABEL=“int drive” BLOCK_SIZE=“512” UUID=“B2DEC265DEC22209” TYPE=“ntfs” PARTLABEL=“intdrive” PARTUUID=“d9f514fd-8ab7-48e3-8476-7f17b9607fef”
/dev/sr1: BLOCK_SIZE=“2048” UUID=“2014-02-27-17-23-21-00” LABEL=“3InternetManager” TYPE=“iso9660” PTTYPE=“mac”
the one im trying to mount here is /dev/sdb1
NTFS changes some things
I’ll need the terminal output of …
id
uid=1000(honnoji) gid=1001(honnoji) groups=1001(honnoji),3(sys),19(log),90(network),94(floppy),96(scanner),98(power),983(rfkill),985(users),986(video),988(storage),990(optical),991(lp),995(audio),998(wheel),999(adm),1000(autologin)
i also changed the label of the drive which at least solved one problem i had specific to wine, the space in its name indeed caused a problem
however there is still he problem of it not being seen as a drive or empty when anything wine related runs
Create a mountpoint
sudo mkdir /mnt/myntfsdrive
Open /etc/fstab in editor
sudo leafpad /etc/fstab
Add the following line …
UUID=B2DEC265DEC22209  /mnt/myntfsdrive  ntfs-3g user,exec,windows_names,uid=1000,gid=1001,dmask=022,fmask=133,umask=0022 0 0
Save the file & reboot
You can read about the ntfs-options added to the fstab in the ArchWiki
thank you, it seems like i was on the right track with my version of the command but had just left out a lot.
Solved the only other problem i had left here, tho i will try to read on the archwiki again if i find myself knowledgeable enough to understand it.
I have found myself relying on mount units - they provide a nice easy to understand implementation for the sometimes
 approach of editing fstab.
They are reusable as in - I store them with my dotfiles - and when I have reinstalled - which I do fairly often - copy them to the /etc/systemd/system - and enable them - with a second script to map my folders into my new home. It takes a couple of minutes after the install - to be fully up and running.
Great that you got the problem solved! ![]()
And please, do not hesitate to ask if you find anything too hard on the Arch wiki pages.
We all have been and still are newbies, learning new stuff every day. ![]()
What OS are you using ?
why templeOS of course
