I am having some trouble with my sound driver on XPS-13 (9315) on a fresh install.
dmesg provides the following errors (repeated many times):
[ 70.777719] rt715-sdca sdw:0:3:025d:0714:01: SDW_SCP_BUS_CLOCK_BASE write failed:-61
[ 70.777721] rt715-sdca sdw:0:3:025d:0714:01: Slave 6 initialization failed: -61
[ 70.781933] rt715-sdca sdw:0:3:025d:0714:01: Slave 6 state check1: UNATTACHED, status was 1
This is the inxi output:
Device-1: Intel Alder Lake Imaging Signal Processor driver: N/A
Device-2: Intel Alder Lake Smart Sound Audio
driver: sof-audio-pci-intel-tgl
API: ALSA v: k6.6.70-1-lts status: kernel-api
Server-1: PipeWire v: 1.2.7 status: active
This error can lock the computer and when shutting down the above error messages keep repeating in the console output, so I have to longpress the power button to get out of the loop.
Have you tried new kernel 6.12?
I had sound issues on my laptop with an Intel sound card. It could be sof-software. Which version of sof-software are you using?
It feels like a hardware conflict/irq conflict as the device is not initialized.
Maybe a bios update?
Check in bios that the sound device is enabled (you probably already did that of course)
Try to disable devices you don’t need (like parallel or serial ports etc.) to free up irq’s
