Hi All,
Yesterday I installed Endeavour for the first time on my Thinkpad T440p (Whitelist removed BIOS for WiFi), Everything was working great yesterday, even through reboots, however today I booted up my machine to no WiFi, my troubleshooting steps were as follows:
Run ifconfig, interface is not present
lspci -k
03:00.0 Network controller: Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
running dmesg tells me the firmware is failing to start but I cannot make sense of why:
[eob@eobT440p /]$ sudo dmesg | grep iwlwifi
[ 2.279300] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 2.279317] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.34
[ 2.279601] iwlwifi 0000:03:00.0: loaded firmware version 67.8f59b80b.0 ty-a0-gf-a0-67.ucode op_mode iwlmvm
[ 3.730386] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 3.746025] iwlwifi 0000:03:00.0: WRT: Failed to set DRAM buffer for alloc id 1, ret=-1
[ 3.746028] iwlwifi 0000:03:00.0: WRT: Failed to set DRAM buffer for alloc id 2, ret=-1
[ 3.746030] iwlwifi 0000:03:00.0: WRT: Failed to set DRAM buffer for alloc id 3, ret=-1
[ 4.767514] iwlwifi 0000:03:00.0: SecBoot CPU1 Status: 0x7022, CPU2 Status: 0xb03
[ 4.767554] iwlwifi 0000:03:00.0: UMAC PC: 0x8047f8e0
[ 4.767579] iwlwifi 0000:03:00.0: LMAC PC: 0x0
[ 4.767582] iwlwifi 0000:03:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 4.767729] iwlwifi 0000:03:00.0: Loaded firmware version: 67.8f59b80b.0 ty-a0-gf-a0-67.ucode
[ 4.767732] iwlwifi 0000:03:00.0: 0x00000000 | ADVANCED_SYSASSERT
[ 4.767734] iwlwifi 0000:03:00.0: 0x00000000 | trm_hw_status0
[ 4.767736] iwlwifi 0000:03:00.0: 0x00000000 | trm_hw_status1
[ 4.767738] iwlwifi 0000:03:00.0: 0x00000000 | branchlink2
[ 4.767740] iwlwifi 0000:03:00.0: 0x00000000 | interruptlink1
[ 4.767742] iwlwifi 0000:03:00.0: 0x00000000 | interruptlink2
[ 4.767743] iwlwifi 0000:03:00.0: 0x00000000 | data1
[ 4.767745] iwlwifi 0000:03:00.0: 0x00000000 | data2
[ 4.767747] iwlwifi 0000:03:00.0: 0x00000000 | data3
[ 4.767748] iwlwifi 0000:03:00.0: 0x00000000 | beacon time
[ 4.767750] iwlwifi 0000:03:00.0: 0x00000000 | tsf low
[ 4.767751] iwlwifi 0000:03:00.0: 0x00000000 | tsf hi
[ 4.767753] iwlwifi 0000:03:00.0: 0x00000000 | time gp1
[ 4.767755] iwlwifi 0000:03:00.0: 0x00000000 | time gp2
[ 4.767756] iwlwifi 0000:03:00.0: 0x00000000 | uCode revision type
[ 4.767758] iwlwifi 0000:03:00.0: 0x00000000 | uCode version major
[ 4.767760] iwlwifi 0000:03:00.0: 0x00000000 | uCode version minor
[ 4.767761] iwlwifi 0000:03:00.0: 0x00000000 | hw version
[ 4.767763] iwlwifi 0000:03:00.0: 0x00000000 | board version
[ 4.767764] iwlwifi 0000:03:00.0: 0x00000000 | hcmd
[ 4.767766] iwlwifi 0000:03:00.0: 0x00000000 | isr0
[ 4.767768] iwlwifi 0000:03:00.0: 0x00000000 | isr1
[ 4.767769] iwlwifi 0000:03:00.0: 0x00000000 | isr2
[ 4.767771] iwlwifi 0000:03:00.0: 0x00000000 | isr3
[ 4.767772] iwlwifi 0000:03:00.0: 0x00000000 | isr4
[ 4.767774] iwlwifi 0000:03:00.0: 0x00000000 | last cmd Id
[ 4.767776] iwlwifi 0000:03:00.0: 0x00000000 | wait_event
[ 4.767777] iwlwifi 0000:03:00.0: 0x00000000 | l2p_control
[ 4.767779] iwlwifi 0000:03:00.0: 0x00000000 | l2p_duration
[ 4.767781] iwlwifi 0000:03:00.0: 0x00000000 | l2p_mhvalid
[ 4.767782] iwlwifi 0000:03:00.0: 0x00000000 | l2p_addr_match
[ 4.767784] iwlwifi 0000:03:00.0: 0x00000000 | lmpm_pmg_sel
[ 4.767785] iwlwifi 0000:03:00.0: 0x00000000 | timestamp
[ 4.767787] iwlwifi 0000:03:00.0: 0x00000000 | flow_handler
[ 4.767841] iwlwifi 0000:03:00.0: Start IWL Error Log Dump:
[ 4.767842] iwlwifi 0000:03:00.0: Transport status: 0x00000042, valid: 7
[ 4.767845] iwlwifi 0000:03:00.0: 0x201013F2 | ADVANCED_SYSASSERT
[ 4.767847] iwlwifi 0000:03:00.0: 0x00000000 | umac branchlink1
[ 4.767849] iwlwifi 0000:03:00.0: 0x8045E20E | umac branchlink2
[ 4.767851] iwlwifi 0000:03:00.0: 0x00000000 | umac interruptlink1
[ 4.767853] iwlwifi 0000:03:00.0: 0x00000000 | umac interruptlink2
[ 4.767854] iwlwifi 0000:03:00.0: 0x0000000C | umac data1
[ 4.767856] iwlwifi 0000:03:00.0: 0x00040000 | umac data2
[ 4.767858] iwlwifi 0000:03:00.0: 0xDEADBEEF | umac data3
[ 4.767859] iwlwifi 0000:03:00.0: 0x00000043 | umac major
[ 4.767861] iwlwifi 0000:03:00.0: 0x8F59B80B | umac minor
[ 4.767863] iwlwifi 0000:03:00.0: 0x0001116A | frame pointer
[ 4.767865] iwlwifi 0000:03:00.0: 0xC0887F34 | stack pointer
[ 4.767866] iwlwifi 0000:03:00.0: 0x00000000 | last host cmd
[ 4.767868] iwlwifi 0000:03:00.0: 0x00000000 | isr status reg
[ 4.767901] iwlwifi 0000:03:00.0: IML/ROM dump:
[ 4.767903] iwlwifi 0000:03:00.0: 0x00000B03 | IML/ROM error/state
[ 4.767926] iwlwifi 0000:03:00.0: 0x00007022 | IML/ROM data1
[ 4.767948] iwlwifi 0000:03:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 4.767967] iwlwifi 0000:03:00.0: Fseq Registers:
[ 4.767979] iwlwifi 0000:03:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 4.767990] iwlwifi 0000:03:00.0: 0x00440005 | FSEQ_TOP_INIT_VERSION
[ 4.768002] iwlwifi 0000:03:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 4.768013] iwlwifi 0000:03:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 4.768025] iwlwifi 0000:03:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 4.768037] iwlwifi 0000:03:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 4.768049] iwlwifi 0000:03:00.0: 0x00400410 | FSEQ_CNVI_ID
[ 4.768060] iwlwifi 0000:03:00.0: 0x00400410 | FSEQ_CNVR_ID
[ 4.768072] iwlwifi 0000:03:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 4.768085] iwlwifi 0000:03:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 4.768099] iwlwifi 0000:03:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 4.768113] iwlwifi 0000:03:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 4.768124] iwlwifi 0000:03:00.0: Failed to start RT ucode: -110
[ 4.768127] iwlwifi 0000:03:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 6.426084] iwlwifi 0000:03:00.0: Failed to run INIT ucode: -110
[ 6.438562] iwlwifi 0000:03:00.0: retry init count 0
it then retries a couple of times before stopping altogether, I can see there is an issue with the firmware starting but I cannot figure out why, I was wondering if anyone could shed some more light on the situation?
EDIT: I am currently running the latest non-LTS kernel, I have seen some reports of issues with the latest kernel so I will switch to LTS and report back.
EDIT: This did not make a difference, same behaviour on LTS
Thanks in advance.
