Installing Screen Freezes on %37
I downloaded iso and burned with rufus on my 32 gb usb. When i started installing freezes on %37 on every DE. Generally freezes on libXdamage installing.
Are you talking about the progress bar in Calamares that hangs on 37% or does the installation actually freeze?
The progress bar seems to freeze at 37% but in reality, the system is downloading and installing. Just wait patiently, the time of installation depends on your internet connection and which mirror it is downloading from.
no i waited like 6-7 hours but its not installed. And my mouse is freezes.
It might not hurt to create a new live ISO and use another method such as etcher on Windows. You could also try updating the mirrors first before running the installer.
