I am trying to install CodeWeavers CrossOver
AUR seems to have a repository for Crossover
so git clone https://tinyurl.com/nqeqk3l
sudo makepkg -si returned the bellow ERRORS
I suspect it is to do with 32 and 64 bits (I had similar problem with PureOS but not on Debian Bullseye)
Is this solvable on EOS?
Ahh, no.
I suppose this is the section you’re talking about
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
#[multilib-testing]
#Include = /etc/pacman.d/mirrorlist
[multilib]
[endeavouros]
SigLevel = PackageRequired
Include = /etc/pacman.d/endeavouros-mirrorlist
No, if you haven’t enabled other testing repos in that file.
You can try installing the dependencies with pacman in advance as well.
Usually it is best to show the full output of a failing command. If the output is long, you can use e.g. eos-sendlog command, piping it to pastebin and show the returned URL here.
