Installing and using NordVPN
Hi all
New arrival here from Mint … looking good so far :smiley:
I want to install NordVPN, preferably with a graphical interface of some sort. I’m already a subscriber and in Mint I could use a Python-based launcher that would give a list of countries and then servers to select from.
Anything similar to this in EOS, and if so, what is a safe way of setting this up?
Many thanks.
I havent’t used it personally but NordPy is in the AUR. You can install it with:
yay -S nordpy
If you can do without a GUI, you can create your vpn connections in the NetworkManager already installed in your system. A little bit manual work needed.
Brilliant, thanks dalto.
Hi cactux (neat pun, BTW) :smiley:
A GUI is not critical, just easier. However, if this is something doable in the NM, then that’s fine. Do you have any links to a decent tutorial on how to set this up. I’m using Mate if this matters?
Cheers
I’m not that familiar with Mate but the principle should be the same.
https://wiki.archlinux.org/title/NordVPN#Alternative_Method:_Connecting_to_NordVPN_using_NetworkManager
Scroll down to: How to set up a VPN on Linux with Network Manager
NordVPN is not that good or trustworthy if I were you I would go with Mullvad VPN
I used them for years and thy keep NOTHING(thy were raided in the past, thy got nothing from them).
Thy have an excellent Linux version that works much better then NordVPN(sure i have not tried in years) .
Mullvad VPN
Are they good for accessing georestricted content?
I use Mullvad VPN. I have for years. And yes, it does work for georestricted content as far as I can tell…
Mullvad DISABLED (I’m in the U.S.):
Mullvad ENABLED (I chose London):
Yes! I use it for that!(like Netflix) thy have servers all over the world!
Thanks all - now sorted. Not the GUI I’ve been used to, but when in Rome … :smiley:
Cheers
