trying a fresh install with online install kde on a hidpi computer. Noticed welcome screen is very small and difficult to read. Can i do something to make the install readable ?
Desktop will be KDE
Hallo Kees,
It’s when starting the installation. System with nvidia gpu and a made the choice to start with nvidia which is a give option
LiveSession is still on X11 so it does not have all the latest options, we will switch soon.
But you can change screen resolution or scale and logout the session this should make welcome bigger. (logging out session will autostart the session right away again)
Thanks for the update.
