Installation failure due to mirror issues
I am installing EOS second time after non creation of efi boot partition during first installation by using replace method.
But i am getting mirror errors while installation, i updated the mirror list, ranked it but the issue doesn’t go away. Please help.
Here is the image of the complete error.
Here is the install log:
https://termbin.com/oeiw
Those are network issues.
Your DNS isn’t working.
Before running the install, can you open the web browser in the Live ISO and confirm you can surf the web?
Or try:
ping -c 3 google.com
ping -c 3 1.1.1.1
Yup that was the issue, got it fixed, i reflashed the iso, and then changed networks but now it proceeded further and new issue occured saying
Installation failed, Failed to run pacstrap
Details: failed to run pacman, here is the installation log:
https://termbin.com/tu3x
I got it fixed, well it somehow fixed itself when i relfashed iso, and changed networks
That is the same issue. The network failed just a bit later in the process so the error is different.
So the problem is my network?
If yes, then let me change to another wifi, and update you soon.
Yes. It looks like your network is dropping.
This was the solution, a new and faster network helped with faster and error free installation. Thank you.
