When I try to install ENOS it fails.
Hi had the same when installing with Nvidia hybrid card. The only thing that worked for me is install with nouveau driver first.
Then install Nvidia in your installed system. Hopefully this is fixed in the upcoming iso. That started happening since Nvidia 495 update. Also the nvidia-installer-dkms installer script did not work for me. Had to manually install drivers.
Are you running a hybrid Nvidia/Intel card?
Hi mate, not hybrid no but I’m trying install right now without the nonfree drivers as you suggested. I’ll post how I get on.
Thanks Zircon34 , this worked. Installed without nonfree drivers and bingo all is good.
the timeout was set to short for the chrooted_cleaner_script running on last release… this is for sure solved already for next release
as nvidia-dkms needs some time to build the modules… it will help to install on nouveau.
Thanks Joe
