Installation failed, boost.python error
Trying to install KDE, received this error. Out of curiosity, does Galileo create an EFI partition out of the main partition you select, or can you choose a partition to install it to?
Thanks
<div><strong>&lt;class 'FileNotFoundError'&gt;</strong></div><div>[Errno 2] No such file or directory: '/tmp/calamares-root-t443nafz/efi/loader/loader.conf'</div><div><br/>Traceback:</div><div><pre>File &quot;/usr/lib/calamares/modules/bootloader/main.py&quot;, line 898, in run
    prepare_bootloader(fw_type)
  File &quot;/usr/lib/calamares/modules/bootloader/main.py&quot;, line 863, in prepare_bootloader
    install_systemd_boot(efi_directory)
  File &quot;/usr/lib/calamares/modules/bootloader/main.py&quot;, line 533, in install_systemd_boot
    create_loader(loader_path, installation_root_path)
  File &quot;/usr/lib/calamares/modules/bootloader/main.py&quot;, line 258, in create_loader
    with open(loader_path, 'w') as loader_file:
         ^^^^^^^^^^^^^^^^^^^^^^</pre></div>
We need the actual installer log to see what is happening.
It depends which installation option you select. It will re-use an EFI partition if it finds one that is suitable.
