Installation ends up with some remarkable result
installation ends up with some remarkable result…
otal Download Size:     11,44 MiB
Total Installed Size:  3512,35 MiB
Net Upgrade Size:        85,42 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 libfilezilla-1:0.37.2-1-x86_64  338,2 KiB  89,2 KiB/s 00:04 [--------------------------------] 100%
 libinih-55-2-x86_64              15,4 KiB   144 KiB/s 00:00 [--------------------------------] 100%
 zstd-1.5.2-5-x86_64             481,9 KiB   106 KiB/s 00:05 [--------------------------------] 100%
 wxgtk-common-3.0.5.1-3-x86_64     2,3 MiB   287 KiB/s 00:08 [--------------------------------] 100%
 filezilla-3.60.1-1-x86_64         4,2 MiB   384 KiB/s 00:11 [--------------------------------] 100%
 wxgtk3-3.0.5.1-3-x86_64           4,1 MiB   346 KiB/s 00:12 [--------------------------------] 100%
 Total (6/6)                      11,4 MiB   972 KiB/s 00:12 [--------------------------------] 100%
(347/347) checking keys in keyring                           [--------------------------------] 100%
(347/347) checking package integrity                         [--------------------------------] 100%
error: zstd: signature from "Maxime Gauduin <alucryd@gmail.com>" is marginal trust
:: File /var/cache/pacman/pkg/zstd-1.5.2-5-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] ^C
Interrupt signal received
[martin@martineos ~]$
what would you do here
btw: some mintes ago - i received this
libxdamage-1.1.5-4-x86_64         7,1 KiB   162 KiB/s 00:00 [--------------------------------] 100%
 libxshmfence-1.3-3-x86_64         5,6 KiB   122 KiB/s 00:00 [--------------------------------] 100%
 systemd-sysvcompat-251.2-1...     5,6 KiB   112 KiB/s 00:00 [--------------------------------] 100%
 pipewire-alsa-1:0.3.52-1-x...     4,8 KiB   105 KiB/s 00:00 [--------------------------------] 100%
 fuse-common-3.11.0-1-x86_64       2,6 KiB  60,0 KiB/s 00:00 [--------------------------------] 100%
 Total (284/284)                 149,7 MiB  1111 KiB/s 02:18 [--------------------------------] 100%
(343/343) checking keys in keyring                           [--------------------------------] 100%
(343/343) checking package integrity                         [--------------------------------] 100%
Do you want to delete it? [Y/n] y
error: libinih: signature from "Maxime Gauduin <alucryd@gmail.com>" is marginal trust
:: File /var/cache/pacman/pkg/libinih-55-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
[martin@martineos ~]$ yay -Syu filezilla
i do not know what to do here.
Refresh your keyring and try again.
Edit:
pacman -Sy archlinux-keyring && pacman -Su
hi - many many thanks.
this worked greatly
(15/27) Fix 'grub' and 'os-prober' after upgrading either of them.
===> INFO: grub-tools / grub-fix-initrd-generation:
===> INFO: /etc/grub.d/30_os-prober changed. See file /var/log/grub-fix-initrd-generation.log.
===> INFO: /etc/grub.d/10_linux changed. See file /var/log/grub-fix-initrd-generation.log.
Generating grub configuration file ...
Found theme: /boot/grub/themes/EndeavourOS/theme.txt
Found linux image: /boot/vmlinuz-linux
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot:  intel-ucode.img initramfs-linux-fallback.img
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
done
(16/27) Update EndeavourOS specific hooks.
(17/27) Check if user should be informed about rebooting after certain system package upgrades.
==> INFO: Reboot is recommended due to the upgrade of core system package(s).
(18/27) Updating fontconfig cache...
(19/27) Probing GDK-Pixbuf loader modules...
(20/27) Updating GIO module cache...
(21/27) Compiling GSettings XML schema files...
(22/27) Probing GTK3 input method modules...
(23/27) Updating icon theme caches...
(24/27) Reloading GVFS config...
(25/27) Checking which packages need to be rebuilt
(26/27) Updating the info directory file...
(27/27) Updating the desktop file MIME type cache...
[root@martineos martin]# yay -Syu filezilla
 -> Avoid running yay as root/sudo.
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
 endeavouros is up to date
resolving dependencies...
Package (4)             New Version  Net Change
community/libfilezilla  1:0.37.2-1     1,13 MiB
extra/wxgtk-common      3.0.5.1-3     11,22 MiB
extra/wxgtk3            3.0.5.1-3     15,08 MiB
community/filezilla     3.60.1-1      15,89 MiB
Total Installed Size:  43,32 MiB
(4/4) checking keys in keyring                               [--------------------------------] 100%
(4/4) checking package integrity                             [--------------------------------] 100%
(4/4) loading package files                                  [--------------------------------] 100%
(4/4) checking for file conflicts                            [--------------------------------] 100%
:: Processing package changes...
(1/4) installing wxgtk-common                                [--------------------------------] 100%
(2/4) installing wxgtk3                                      [--------------------------------] 100%
Optional dependencies for wxgtk3
    webkit2gtk: for webview support [installed]
(3/4) installing libfilezilla                                [--------------------------------] 100%
(4/4) installing filezilla                                   [--------------------------------] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating icon theme caches...
(3/3) Updating the desktop file MIME type cache...
:: Searching databases for updates...
:: Searching AUR for updates...
 there is nothing to do
many thanks
If your issue is solved, please mark @pycrk’s post as the solution.
https://wiki.archlinux.org/title/Pacman/Package_signing#Invalid_signature_errors
Also
