Inside border in Xfce terminal
Hi,
I am using EndeavourOS Xfce and when I open my cli it looks like this:
Which is fine. However, when I launch ncspot (a Spotify client), it looks like this:
There is an inside border. Do you know how I can get rid of that inside border?
When using the Urxvt/xrvt terminal it looks fine, no inside border:
Thank you.
Alternatively, how can I change the default terminal to urxvt/rxvt? I tried to do so in the “default applications” settings, but it didn’t change anything.
Thank you.
Hum, solved. Changing in “default applications” settings works fine.
