I was installing Inkscape and I got a lxml error when trying to open eps files in inkpscape or importing them, so I tried to search for answers and I got the python-lxml to install it solution.
It works simple as that, just install it and there you go!
You can always see which packages add extra functionality by checking the optional dependencies, for example:
$pacman -Si inkscape
Optional Deps : fig2dev: xfig input
gvfs: import clip art
pstoedit: latex formulas
python-lxml: some extensions
python-numpy: some extensions
scour: optimized SVG output, some extensions
texlive-core: latex formulas
Did not know that, try it on gimp too, thanks a lot!
