Hi. Today i’m already try and installing EndeavourOS Galileo offline installation with KDE Plasma 5.27 after installing i open the start menu to view installed program i’m noticed with “File Roller” when i attempt to uninstall via command “sudo pacman -Rns file-roller” I’m shock because i"ll uninstalled few packages including libhandy, xdg-desktop-portal-gtk, zip, and geoclue when i answer y system tray become empty including firewalld as i recall. So i installed EndeavourOS twice. You should fix them in next release.
As far i Know file-roller should installed with gnome or cinnamon, xarchiver with xfce and ark with KDE Plasma.
Not an installation / distro issue. This is user error. Read up on the various versions of -R -Rn -Rns -Rdd etc. When you ran -Rns you removed several of its dependencies as seen here:
Thanks. Btw i’ll ask some question to you. Usage of xdg-desktop-portal-gtk and xdg-desktop-portal-kde is dependency? Because i saw in package.debian.org is dependency. And in kubuntu 23.10 also installed and running in the background in KDE System Monitor. So i had installed manually.
Those are dependencies for some packages, yes. However, when you install those packages, they will ask you to install one of the xdg-desktop-portal-* packages.
If you are running plasma, it is best to only install xdg-desktop-portal-kde unless some packages explicitly requires xdg-desktop-portal-gtk which would be uncommon.
