Im with a weird problema with base-devel
[:red_circle:] × sudo pacman -S base-devel
warning: base-devel-1-2 is up to date – reinstalling
resolving dependencies…
looking for conflicting packages…
error: could not open file /var/lib/pacman/local/base-devel-1-2/files: No such file or directory
warning: could not fully load metadata for package base-devel-1-2
error: failed to prepare transaction (invalid or corrupted package)
[:red_circle:] × yay -S base-devel
Sync Explicit (1): base-devel-1-2
→ error installing repo packages
Does that file exist on your system? If not try just creating it, it’s an empty file on my system.
sudo touch /var/lib/pacman/local/base-devel-1-2/files
now the error changed
╭─serejo1@serejo in ~ as :mage: took 0s
Try running: sudo pacman -Syu base-devel
return it
╰─λ sudo pacman -Syu base-devel
:: Synchronizing package databases…
endeavouros is up to date
core is up to date
extra is up to date
multilib is up to date
:: Starting full system upgrade…
warning: dracut: local (107-1) is newer than endeavouros (106-1)
Try running this.
sudo rm -rf /var/lib/pacman/local/base-devel-1-2/
sudo rm /var/cache/pacman/pkg/base-devel-1-2-any.pkg.tar.zst
that really did fix it
