Im having Issues with setup
Hello im trying to install EndeavorOS and im running into issues.
https://termbin.com/fxbi9
Thats the log outputted by the system installer
welcome on the purple road :enos:
=== START CALAMARES 3.2.60
2022-10-14 - 15:06:40 [6]: void CalamaresApplication::init()
    Calamares version: 3.2.60
this is an outdated ISO you need latest ISO.
it fails here:
initialize pacman ... ranking mirrors ... copy pacman mirrorlist and keyring to target
    Starting job "initialize pacman ... ranking mirrors ... copy pacman mirrorlist and keyring to target ..." ( 13 / 43 )
2022-10-14 - 16:16:39 [6]:     .. Running ("/bin/sh", "-c", "pacman -Sy --noconfirm archlinux-keyring endeavouros-keyring")
2022-10-14 - 16:16:51 [6]: QML Component (default slideshow) Next slide
2022-10-14 - 16:16:55 [6]:     .. Running ("/bin/sh", "-c", "chmod +x /etc/calamares/scripts/create-pacman-keyring")
2022-10-14 - 16:16:55 [6]:     .. Running ("/bin/sh", "-c", "bash /etc/calamares/scripts/create-pacman-keyring")
2022-10-14 - 16:16:57 [6]:     .. Running ("/bin/sh", "-c", "bash /etc/calamares/scripts/update-mirrorlist")
2022-10-14 - 16:17:21 [6]: QML Component (default slideshow) Next slide
2022-10-14 - 16:17:31 [6]:     .. Running ("/bin/sh", "-c", "cp /etc/pacman.d/mirrorlist /tmp/calamares-root-6484q6mw/etc/pacman.d/")
2022-10-14 - 16:17:31 [6]:     .. Running ("/bin/sh", "-c", "cp -a /etc/pacman.d/gnupg /tmp/calamares-root-6484q6mw/etc/pacman.d/")
2022-10-14 - 16:17:31 [6]:     .. Target cmd: ("/bin/sh", "-c", "cp -a /etc/pacman.d/gnupg /tmp/calamares-root-6484q6mw/etc/pacman.d/") Exit code: 1 output:
 cp: cannot create special file '/tmp/calamares-root-6484q6mw/etc/pacman.d/gnupg/S.gpg-agent': Operation not permitted
cp: cannot create special file '/tmp/calamares-root-6484q6mw/etc/pacman.d/gnupg/S.gpg-agent.extra': Operation not permitted
cp: cannot create special file '/tmp/calamares-root-6484q6mw/etc/pacman.d/gnupg/S.gpg-agent.browser': Operation not permitted
cp: cannot create special file '/tmp/calamares-root-6484q6mw/etc/pacman.d/gnupg/S.gpg-agent.ssh': Operation not permitted
2022-10-14 - 16:17:31 [6]: virtual void Calamares::JobThread::run()
    Skipping non-emergency job "pacstrap"
Could be in addition that something is setup wrong on partitions?
You where using manually partitoning and resizing a partition?
What exactly do you setup for partitions?
It looks like you made your / partition fat32.
That filesystem isn’t POSIX compliant. You can’t install Linux on it.
Ohhh, That makes sense, What would work then? I just clicked the one that i recognized
ext4 is the most common option.
Thanks i will try that, I’ll keep you updated!
Hey so that fixed the original problem but im now facing another problem
https://termbin.com/ee79
That is because you are using an old ISO.
Try unchecking “ipw2100-fw” and “ipw2200-fw” on the screen that lets you choose packages to install or not.
2022-10-14 - 15:31:44 [6]:     ..  mapping for "" "New Partition"
     partlabel :   ""
     partition-uuid (partuuid) :   "PartUUID$47"
     parttype :   ""
     partattrs :   "0"
     mountPoint: :   "/"
     fs: :   "fat32"
     fsName :   "fat32"
     filesystem-uuid (uuid) :   "FSUUID$70"
     claimed :   "true"
good eye… :wink:
Im just gonna get the newer .iso brb
Hey so i cant boot into windows… no idea why, When i try to boot into windows it says something along these lines “No bootable usb drive or floopy detected press any key to try again or restart system”. Does anybody know whats going on with this? (Alll of my files appear inside the live boot where im writing this)
depending on what else you do on partitioning the drives? could you show the output of:
lsblk -f
you can generate pastebin and send URL too
lsblk -f | eos-sendlog
Here you go!
https://clbin.com/pJt6v
sry for delay… just back here ,
sda
├─sda1 ntfs                                 904CCFF74CCFD65E
└─sda2 ntfs                                 F248478D48475011
so first drive looks like it is holding windows…
and second:
sdb
├─sdb1 ntfs           Reservert av systemet 6E3AC76D3AC7313F
├─sdb2 ntfs           Nytt volum            262CA9CC2CA99779
├─sdb3 ext4     1.0                         50c576f2-b491-40b5-8c39-402ef97f15b0
└─sdb4 vfat     FAT32 NO_LABEL              5FBB-12CF
nytt volum means new volume.. looks like you add this for data used by windows before?
But as far as i can see your winows partitions are intact but i do not see any ESP from windows… (the fat32 partition from bootloader) is windows installed in legacy mode?? and you changed to uefi in Bios/Firmware to get Linux installed?
giving
sudo fdisk -l | eos-sendlog
would show more info on partitions
Hey so windows is installed in legacy mode. And i dont think i changed it to uefi but i can check (is it in the bios menu?). And nytt volum is just another drive i added for more storage space
yes i want only to see if you accidently removed something windows needs… but looks like system is set to uefi now and so it can not boot windows installed din Bios/legacy/CSM mode… every Bios/Firmware is different… look for the 3 names Bios Legacy CSM and boot options… should be self-explaining in most cases…
