Hi, yesterday I upgraded my system together with KDE and since then I have a problem with icons in a panel disappearing together with when alt-tabbing i don’t see a preview of the app. Maybe there are more bugs i have not found yet. When using wayland its even worse, when alt-tabbing the whole desktop environment restarts for example, so i switched to x11 where only the bugs described above are present. I messed up the upgrade (PC shut down during upgrade) and the system didn’t even want to boot at start. The problem was with root partition having different linux kernel than EFI, after I fixed that, the graphical interface didn’t want to load but after reinstalling the packages it started to work, not sure if that’s relevant though. Has anyone encountered this?
Here are some information about my system, not sure if anything else is necessary:
KDE Plasma version: 6.0.1
KDE Frameworks version: 6.0.0
Qt version: 6.6.2
Kernel version: 6.7.9-arch-1-1 (64-bit)
Graphics Platform: X11
Graphics: Nvidia Geforce RTX 2060/PCIe/SSE2
$ dmesg | grep -i nvidia
[ 0.000000] Command line: initrd=\023d6c1020cc451eb0de453f924e6a68\6.7.9-arch1-1\initrd nvme_load=YES nowatchdog rw root=UUID=55f69e10-d26c-4d37-aba6-97445a775e70 nvidia-drm.modeset=1 systemd.machine_id=023d6c1020cc451eb0de453f924e6a68
[ 0.036673] Kernel command line: initrd=\023d6c1020cc451eb0de453f924e6a68\6.7.9-arch1-1\initrd nvme_load=YES nowatchdog rw root=UUID=55f69e10-d26c-4d37-aba6-97445a775e70 nvidia-drm.modeset=1 systemd.machine_id=023d6c1020cc451eb0de453f924e6a68
[ 1.475601] nvidia: module license 'NVIDIA' taints kernel.
[ 1.475613] nvidia: module license taints kernel.
[ 2.039991] nvidia-nvlink: Nvlink Core is being initialized, major device number 240
[ 2.042019] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[ 2.092764] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.54.14 Thu Feb 22 01:44:30 UTC 2024
[ 2.135364] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 2.140569] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 550.54.14 Thu Feb 22 01:25:25 UTC 2024
[ 2.293998] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 2.294114] nvidia-uvm: Loaded the UVM driver, major device number 238.
[ 3.013605] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 3.013899] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 3.016025] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ 4.935725] nvidia-gpu 0000:01:00.3: enabling device (0000 -> 0002)
[ 4.943240] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 5.078241] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 5.431030] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input16
[ 5.431126] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input17
[ 5.431212] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input18
[ 5.431320] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input19
[ 6.008136] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 6.109631] nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
[ 8.497628] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 8.975738] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 9.889727] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 23.443044] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 23.909725] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 29.114110] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 29.118284] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 110.989548] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 111.022922] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 111.976228] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 112.086610] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 112.898093] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 113.816536] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 124.218743] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 124.222617] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 125.174090] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 126.909673] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 126.912442] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 127.091238] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 128.027251] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 147.320957] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 147.324114] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 148.268482] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 148.470340] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 149.280189] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 150.214307] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 161.834105] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 162.275641] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 167.145210] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 167.149661] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 196.248762] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[ 196.248885] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[ 196.653054] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[ 196.653177] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[ 196.813862] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[ 196.813958] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[ 270.512134] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 270.527288] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 273.725857] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 273.729395] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 273.920034] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 322.331165] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 322.584236] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
[ 840.310714] nvidia-modeset: WARNING: GPU:0: AU Optronics Corporation (DP-2): G-SYNC Compatible: EDID min refresh rate invalid, disabling G-SYNC Compatible.
[ 840.453718] [drm:drm_new_set_master] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership
