So, I have a few questions about i3 config of endaevouros.
There seem to be only three workspaces 2,3,4
I can’t switch to 1,5-9,0 by using $mod + 1,5-9
And also, I have used a lesser resolution 1600x1900 as the default is 1080p i.e 1920x1080
but everything still looks small like in firefox.
I have used archlabs i3 as well but there was no such resolution problem or switching workspaces problem.
Also, the keybindings in my keyboard for brightness control doesn’t work either.
Any help would be greatly appreciated.
#move focused container to workspace
bindsym $mod+2 move container to workspace $ws2
bindsym $mod+3 move container to workspace $ws3
bindsym $mod+4 move container to workspace $ws4
as you can see by default only workspace 2-4 are mentioned here.
If you want the other ones, you can manually add the others here… (just copy the line in your config and change the numbers.
you will have to reload i3 for these changes to have effect
This is possibly a problem with the compositor, but I’ll leave that one up for @joekamprad
I’ve noticed that using picom mostly solved the tearing on my old Dell with Intel graphics.
Didn’t want to make any blind recommendations though, since I don’t really know the technical details of those compositors…
I know there’s also compton, but haven’t even tried that one
picom replaced compton.
picom 8.1-2
Package Actions
Source Files / View Changes
Bug Reports / Add New Bug
Search Wiki
Security Issues
Flag Package Out-of-Date (?)
Download From Mirror
Architecture: x86_64
Repository: Community
Description: X compositor that may fix tearing issues
Upstream URL: https://github.com/yshui/picom
License(s): MIT, MPL
Provides: compton
Replaces: compton
Conflicts: compton
Maintainers: Alexander Rødseth
Package Size: 150.2 KB
Installed Size: 374.5 KB
Last Packager: Alexander Rødseth
Build Date: 2020-09-29 14:22 UTC
Signed By: Alexander Rødseth
Signature Date: 2020-09-29 14:22 UTC
Last Updated: 2020-09-29 14:25 UTC
