[ 3.124144] tpm_crb MSFT0101:00: can't request region for resource [mem 0x8f7a2000-0x8f7a5fff]
[ 3.124152] tpm_crb: probe of MSFT0101:00 failed with error -16
from your dmesg…
you can try disable TPM in Bios/Firmware too…
from your dmesg…
I just tried all the above settings and so far I haven’t gotten any freezes yet,
I ran sudo dmesg | grep -i fail | eos-sendlog
and this is the output:
https://clbin.com/1Ln4e
I don’t think I see any of their outlined errors.
At this point I might just try to do a fresh re-installation of everything when I have a couple of hours of free time. It is really strange though how it just seems to freeze seemingly out of nowhere.
I spent the entire day doing a fresh arch installation (not endeavour) just to get a freeze I don’t even know what to do at this point.
Did you disable TPM?
yes from BIOS
could be somehow kernel related also… i would go try LTS kernel.
When you start this it was not the 6er kernel and your system was still on 5.19… but i would give it a try…
I’ll try that out and report back although I saw a recent thread about AMD causing arch issues on kernel v6 https://gitlab.freedesktop.org/drm/amd/-/issues/2164
Edit: Oh wait I just realized you said LTS kernel not latest my bad
LTS Kernel seemed to have helped a bit although I still got a crash. I'm not entirely sure what they mean but maybe they might help.
-- Boot dd97350d498a47a08adb1acc0539356a --
Oct 21 19:59:58 stephenz kernel: watchdog: BUG: soft lockup - CPU#5 stuck for 23s! [spotify:33932]
Oct 21 19:47:15 stephenz kernel: perf: interrupt took too long (2514 > 2500), lowering kernel.perf_event_max_sample_rate to 79500
Oct 21 19:44:04 stephenz wpa_supplicant[502]: wlp1s0: WPA: Group rekeying completed with 44:a5:6e:24:fb:b6 [GTK=CCMP]
