Maybe you can try the following kernel parameters in the default grub command line and the run the update grub command.
processor.max_cstate=5 rcu_nocbs=0-11
Hmm that didnāt seem to work, thanks anyways though.
Funny enough I loaded up Spotify and played a song and 2 seconds later I got a freeze.
journalctl -r
-- Boot 7b5dd4e58b5c482e8f61823b4f51e6e1 --
Oct 07 18:04:54 stephen-laptop playerctld[1403]: could not get properties for active player: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface āorg.mpris.MediaPlayer2.Playlistsā
Oct 07 18:04:54 stephen-laptop playerctld[1403]: could not get properties for active player: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: No such interface āorg.mpris.MediaPlayer2.TrackListā
Oct 07 18:03:29 stephen-laptop kernel: pcieport 0000:00:08.1: PME: Spurious native interrupt!
Oct 07 17:55:38 stephen-laptop org.flameshot.Flameshot[1354045]: flameshot: info: Capture saved to clipboard.
Iām thinking it probably has something to do with my headphone jack maybe because I had plugged in headphones just as I booted up Spotify.
lspci -vv -t | grep 08.1
could be your hardware not properly working or a kernel regression causing it to fail to load properlyā¦
+-08.1-[02]--+-00.0 Advanced Micro Devices, Inc. [AMD/ATI] Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
Maybe I didnāt install the AMD drivers correctly but Iām pretty sure I did.
I guess I should also provide more context to the freezes because usually after freezing Iām still able to move my mouse around but none of the keyboard inputs work and the windows seem to be frozen as well.
inxi -Ga
will showā¦
inxi -Ga
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Huawei driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 02:00.0
chip-ID: 1002:15dd class-ID: 0300
Device-2: Quanta hm1091_techfront type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 0408:1020 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: Picom v: git-7e568 driver: X: loaded: amdgpu
unloaded: modesetting,vesa alternate: fbdev gpu: amdgpu display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22")
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14d4 built: 2016
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.42
5.15.71-1-lts) v: 4.6 Mesa 22.1.7 direct render: Yes
all fine ā¦
Oct 06 20:58:15 stephen-laptop wireplumber[752]: could not save restore-stream: Failed to create file ā/home/stephen/.local/state/wireplumber/restore-stream.ATVIT1ā: No such file or directory
hmm are permissions right?
ls -l /home/stephen/.local/state/wireplumber
total 8
-rw-r--r-- 1 stephen stephen 642 Oct 8 09:46 default-routes
-rw-r--r-- 1 stephen stephen 1580 Oct 8 11:05 restore-stream
I would try and test another kernel parameter
processor.max_cstate=1
Unfortunately that didnāt work, journalctl didnāt provide anything useful either around the crash time.
Have you checked sudo dmesg | eos-sendlog
Post the link.
https://clbin.com/UbSJf
After crashing a bunch of times I have a suspicion that it might just be the system stopping a lot of services when the memory or cpu usage is too high or something. Just a guess because honestly these crashes are just happening randomly now so I donāt think theyāre tied to a specific application at least.
Iām more and more starting to believe that high memory/cpu usage is the cause of crashing because Iāve crashed 4 times in the past hour from just running a Nextjs dev server although I have crashed before from other applications. Does arch have a way of automatically stopping processes if they are taking too much resources?
If these kernel parameters didnāt help you should remove them and update grub.
processor.max_cstate=1 rcu_nocbs=0-11
Maybe remove those other kernel parameters and add these and update grub to test them.
iommu=soft idle=nomwait
Still got a freeze
Itās weird because of how random they are.
I donāt know what is causing the freezing. There are many kernel parameters for hardware. Iām guessing and the only way is to test them. Is it possible to run journactl something like this when you get a freeze.
sudo journalctl --since ā15 minutes agoā
@Shanks
You might want to try this as a kernel parameter and update grub.
acpi_osi='Windows 2019'
i would do a memory (RAM) test also⦠may Bios/Firmware offer something like that?
