Hi, i am failing at installing i3 by following this tutorial. Basically when executing …
$ wget https://raw.githubusercontent.com/endeavouros-team/EndeavourOS-packages-lists/master/i3
$ sudo pacman -S --needed - < i3
… the output is …
warning: arc-gtk-theme-eos-20221218-2 is up to date -- skipping
warning: endeavouros-xfce4-terminal-colors-6-1 is up to date -- skipping
warning: eos-lightdm-slick-theme-3.2-1 is up to date -- skipping
warning: eos-qogir-icons-6-1 is up to date -- skipping
warning: galculator-2.1.4-10 is up to date -- skipping
warning: gvfs-1.58.0-2 is up to date -- skipping
warning: gvfs-afc-1.58.0-2 is up to date -- skipping
warning: gvfs-gphoto2-1.58.0-2 is up to date -- skipping
warning: gvfs-mtp-1.58.0-2 is up to date -- skipping
warning: gvfs-nfs-1.58.0-2 is up to date -- skipping
warning: gvfs-smb-1.58.0-2 is up to date -- skipping
warning: lightdm-1:1.32.0-6 is up to date -- skipping
warning: lightdm-slick-greeter-2.2.2-1 is up to date -- skipping
warning: mpv-1:0.40.0-7 is up to date -- skipping
warning: network-manager-applet-1.36.0-1 is up to date -- skipping
warning: polkit-gnome-0.105-11 is up to date -- skipping
warning: thunar-4.20.6-1 is up to date -- skipping
warning: thunar-archive-plugin-0.6.0-1 is up to date -- skipping
warning: thunar-volman-4.20.0-2 is up to date -- skipping
warning: tumbler-4.20.1-1 is up to date -- skipping
warning: unzip-6.0-23 is up to date -- skipping
warning: xdg-user-dirs-gtk-0.14-1 is up to date -- skipping
warning: xfce4-terminal-1.1.5-1 is up to date -- skipping
warning: xorg-xdpyinfo-1.4.0-1 is up to date -- skipping
warning: zip-3.0-11 is up to date -- skipping
resolving dependencies...
Package (33) New Version Net Change
extra/confuse 3.3-4 0,14 MiB
extra/libev 4.33-4 0,19 MiB
extra/libpeas 1.36.0-7 0,61 MiB
extra/oniguruma 6.9.10-1 0,88 MiB
extra/xcb-imdkit 1.0.9-1 0,60 MiB
extra/xcb-util-xrm 1.3-4 0,04 MiB
extra/xcur2png 0.7.1-8 0,02 MiB
extra/yajl 2.1.0-6 0,22 MiB
extra/acpi 1.8-2 0,02 MiB
extra/arandr 0.1.11-4 0,31 MiB
extra/archlinux-xdg-menu 0.7.6.6-2 0,13 MiB
extra/awesome-terminal-fonts 1.1.0-5 0,37 MiB
extra/dex 0.9.0-2 0,03 MiB
extra/dmenu 5.4-1 0,05 MiB
extra/dunst 1.13.0-1 0,28 MiB
endeavouros/eos-settings-i3wm 5.1-1 0,13 MiB
extra/feh 3.11.2-2 0,41 MiB
extra/i3-wm 4.24-1 1,79 MiB
extra/i3blocks 1.5-4 0,04 MiB
extra/i3lock 2.15-3 0,05 MiB
extra/i3status 2.15-1 0,12 MiB
extra/jq 1.8.1-1 0,45 MiB
extra/numlockx 1.2-6 0,01 MiB
extra/nwg-look 1.0.6-1 4,35 MiB
extra/playerctl 2.4.1-4 0,44 MiB
extra/rofi 2.0.0-1 1,07 MiB
extra/scrot 1.12.1-1 0,12 MiB
extra/sysstat 12.7.8-1 1,62 MiB
extra/xarchiver 0.5.4.26-1 1,59 MiB
extra/xbindkeys 1.8.7-5 0,05 MiB
extra/xed 3.8.4-1 11,07 MiB
extra/xorg-xbacklight 1.2.4-1 0,02 MiB
extra/xss-lock 0.3.0.r30.gac39fdc-1 0,04 MiB
Total Installed Size: 27,28 MiB
:: Proceed with installation? [Y/n] Y
(33/33) checking keys in keyring [-----------------------------------------------------------------------------------------------------------------------] 100%
(33/33) checking package integrity [-----------------------------------------------------------------------------------------------------------------------] 100%
(33/33) loading package files [-----------------------------------------------------------------------------------------------------------------------] 100%
(33/33) checking for file conflicts [-----------------------------------------------------------------------------------------------------------------------] 100%
error: failed to commit transaction (conflicting files)
eos-settings-i3wm: /etc/skel/.Xresources exists in filesystem (owned by eos-settings-xfce4)
eos-settings-i3wm: /etc/skel/.config/autostart/firewall-applet.desktop exists in filesystem (owned by eos-settings-xfce4)
eos-settings-i3wm: /etc/skel/.config/gtk-3.0/gtk.css exists in filesystem (owned by eos-settings-xfce4)
eos-settings-i3wm: /etc/skel/.config/gtk-3.0/settings.ini exists in filesystem (owned by eos-settings-xfce4)
eos-settings-i3wm: /etc/skel/.config/gtk-4.0/settings.ini exists in filesystem (owned by eos-settings-xfce4)
eos-settings-i3wm: /etc/skel/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-terminal.xml exists in filesystem (owned by eos-settings-xfce4)
Somebody any idea what i could do?
