I need to connect a USB Bluetooth adapter but missing btusb
lsmod | grep btusb
zero…
What can I do?
What kernel are you using?
Post output of uname -r
Is bluetooth enabled ?
https://discovery.endeavouros.com/audio/bluetooth/2021/03/
Enabling bluetooth is also an important part, but that won’t make the btusb kernel driver appear.
uname -r
7.0.14-arch1-1
Have you done any modifications to this kernel?
no
Try to do modprobe btusb so the module loads. This should do it.
Thanks
sudo modprobe btusb
[sudo] Mot de passe de ober :
ober@eos ~ $ lsmod | grep btusb
btusb 86016 0
btmtk 32768 1 btusb
btrtl 32768 1 btusb
btbcm 24576 1 btusb
btintel 73728 1 btusb
bluetooth 1204224 5 btrtl,btmtk,btintel,btbcm,btusb
Mark my message as solved if you’re done with this. Do sudo systemctl enable --now bluetooth to enable bluetooth.
But I still don’t see the USB Bluetooth adapter.
Post the output of lsusb
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 003: ID 046b:ff01 American Megatrends, Inc. Generic Hub
Bus 002 Device 004: ID 046b:ff10 American Megatrends, Inc. Virtual Keyboard and Mouse
Do you know adapter model?
lsusb
Bus 002 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Thanks, I will try to find compatibility.
Thanks, now I can see the adapter and find the headphones.
Nice, mark the post that fixed it as solved so it’s more discoverable.
I can see the headphones, but I can’t hear any signal or audio signal from them yet. Maybe I need special drivers?
Have you checked that the correct audio output is selected?
