Greetings everyone!
So… here’s the problem, I installed EndeavourOS for a while now and I decided to go with swaywm (I’m not using community editions, I installed KDE first before switching over to sway) because I like neither GNOME nor KDE. After setting up the bar and everything, I decided to tackle input options (I’m Vietnamese) and for years I’ve always sticked with https://github.com/BambooEngine/ibus-bamboo
When I run ibus-daemon, I get this:
portal is not running: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.portal.IBus exited with status 1
I really have no idea why, things I’ve tried are:
Installing xdg-desktop-portal (I recalled there’s a package like this and since it says “portal”, I figured it might help)
Installing the lastest ibus-git package from AUR
Messed around with some environment variables such as: XDG_SESSION_TYPE, XDG_CURRENT_DESKTOP
Information on the internet is very limited, I can’t seem to find someone with the same problem as mine. Theirs just work out of the box, so I don’t think a bug report would make sense. I’ve confirmed wayland works. I’ve used it before in KDE Wayland. Running ibus-daemon -drx gives no error though (I’m not sure what it does, found it while researching haha uhhhhhh)
Thanks in advance
