Nov 24 11:08:11 UserName kernel: amdgpu 0000:2f:00.0: amdgpu: bo 00000000da0257b7 va 0x0800000000-0x0800000001 conflict with 0x0800000000-0x0800000200
Nov 24 11:08:11 UserName kernel: amdgpu: Failed to map VA 0x800000000000 in vm. ret -22
Nov 24 11:08:11 UserName kernel: amdgpu: Failed to map bo to gpuvm
Nov 24 11:08:11 UserName kernel: ------------[ cut here ]------------
Nov 24 11:08:11 UserName kernel: refcount_t: addition on 0; use-after-free.
Nov 24 11:08:11 UserName kernel: WARNING: CPU: 7 PID: 4158 at lib/refcount.c:25 refcount_warn_saturate+0xe5/0x110
Nov 24 11:08:11 UserName kernel: Modules linked in: tun dummy snd_seq_dummy snd_hrtimer snd_seq snd_seq_device xt_CHECKSUM xt_MASQUERADE xt_conntrack ipt_REJECT xt_tcpudp nft_compat nf_nat_tftp nf_conntrack_tftp bridge stp llc wireguard curve25519_x86_64 libchac>
Nov 24 11:08:11 UserName kernel: mousedev joydev mac_hid loop fuse ip_tables x_tables dm_crypt cbc encrypted_keys trusted asn1_encoder tee uas usb_storage usbhid crct10dif_pclmul crc32_pclmul polyval_clmulni polyval_generic gf128mul ghash_clmulni_intel sha512_s>
Nov 24 11:08:11 UserName kernel: CPU: 7 PID: 4158 Comm: soffice.bin Not tainted 6.6.2-arch1-1 #1 11215f9ba7ddfb51644674a5b2ced71612c62fe9
Nov 24 11:08:11 UserName kernel: Hardware name: Micro-Star International Co., Ltd. MS-7C37/MPG X570 GAMING PLUS (MS-7C37), BIOS A.L2 06/12/2023
Nov 24 11:08:11 UserName kernel: RIP: 0010:refcount_warn_saturate+0xe5/0x110
Nov 24 11:08:11 UserName kernel: Code: 82 a7 ff 0f 0b e9 cb 43 77 00 80 3d bf be 98 01 00 0f 85 5e ff ff ff 48 c7 c7 f8 28 09 96 c6 05 ab be 98 01 01 e8 3b 82 a7 ff <0f> 0b e9 a4 43 77 00 48 c7 c7 50 29 09 96 c6 05 8f be 98 01 01 e8
Nov 24 11:08:11 UserName kernel: RSP: 0018:ffffc90004d0fc18 EFLAGS: 00010286
Nov 24 11:08:11 UserName kernel: RAX: 0000000000000000 RBX: ffff8881bcab0158 RCX: 0000000000000027
Nov 24 11:08:11 UserName kernel: RDX: ffff888fdebe1708 RSI: 0000000000000001 RDI: ffff888fdebe1700
Nov 24 11:08:11 UserName kernel: RBP: ffff88815ceb0000 R08: 0000000000000000 R09: ffffc90004d0faa0
Nov 24 11:08:11 UserName kernel: R10: 0000000000000003 R11: ffff88901f2a36a8 R12: ffff888128596b38
Nov 24 11:08:11 UserName kernel: R13: ffff888128596b40 R14: ffff8881339a8d80 R15: ffff8881bcab0000
Nov 24 11:08:11 UserName kernel: FS: 00007f7df385e300(0000) GS:ffff888fdebc0000(0000) knlGS:0000000000000000
Nov 24 11:08:11 UserName kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Nov 24 11:08:11 UserName kernel: CR2: 00005624845fad28 CR3: 00000001a317a000 CR4: 0000000000f50ee0
Nov 24 11:08:11 UserName kernel: PKRU: 55555554
Nov 24 11:08:11 UserName kernel: Call Trace:
Nov 24 11:08:11 UserName kernel: <TASK>
Nov 24 11:08:11 UserName kernel: ? refcount_warn_saturate+0xe5/0x110
Nov 24 11:08:11 UserName kernel: ? __warn+0x81/0x130
Nov 24 11:08:11 UserName kernel: ? report_bug+0x171/0x1a0
Nov 24 11:08:11 UserName kernel: ? prb_read_valid+0x1b/0x30
Nov 24 11:08:11 UserName kernel: ? srso_alias_return_thunk+0x5/0x7f
Nov 24 11:08:11 UserName kernel: ? handle_bug+0x3c/0x80
Nov 24 11:08:11 UserName kernel: ? exc_invalid_op+0x17/0x70
Nov 24 11:08:11 UserName kernel: ? asm_exc_invalid_op+0x1a/0x20
Nov 24 11:08:11 UserName kernel: dma_resv_add_fence+0x18f/0x1e0
Nov 24 11:08:11 UserName kernel: amdgpu_amdkfd_gpuvm_acquire_process_vm+0x212/0x530 [amdgpu 0401721894ca8f32d5d0b424349ce03960632e80]
Nov 24 11:08:11 UserName kernel: kfd_process_device_init_vm+0xb0/0x320 [amdgpu 0401721894ca8f32d5d0b424349ce03960632e80]
Nov 24 11:08:11 UserName kernel: ? _copy_to_iter+0x5e/0x4a0
Nov 24 11:08:11 UserName kernel: ? kfd_ioctl_get_process_apertures_new+0x47/0x330 [amdgpu 0401721894ca8f32d5d0b424349ce03960632e80]
Nov 24 11:08:11 UserName kernel: kfd_ioctl_acquire_vm+0x89/0xc0 [amdgpu 0401721894ca8f32d5d0b424349ce03960632e80]
Nov 24 11:08:11 UserName kernel: kfd_ioctl+0x3cc/0x4e0 [amdgpu 0401721894ca8f32d5d0b424349ce03960632e80]
Nov 24 11:08:11 UserName kernel: ? __pfx_kfd_ioctl_acquire_vm+0x10/0x10 [amdgpu 0401721894ca8f32d5d0b424349ce03960632e80]
Nov 24 11:08:11 UserName kernel: ? kfd_ioctl+0x298/0x4e0 [amdgpu 0401721894ca8f32d5d0b424349ce03960632e80]
Nov 24 11:08:11 UserName kernel: __x64_sys_ioctl+0x97/0xd0
Nov 24 11:08:11 UserName kernel: do_syscall_64+0x60/0x90
Nov 24 11:08:11 UserName kernel: ? syscall_exit_to_user_mode+0x2b/0x40
Nov 24 11:08:11 UserName kernel: ? do_syscall_64+0x6c/0x90
Nov 24 11:08:11 UserName kernel: entry_SYSCALL_64_after_hwframe+0x6e/0xd8
Nov 24 11:08:11 UserName kernel: RIP: 0033:0x7f7dfd7783af
Nov 24 11:08:11 UserName kernel: Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 18 48 8b 44 24 18 64 48 2b 04 25 28 00 00
Nov 24 11:08:11 UserName kernel: RSP: 002b:00007ffc4fa10070 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Nov 24 11:08:11 UserName kernel: RAX: ffffffffffffffda RBX: 00007ffc4fa10160 RCX: 00007f7dfd7783af
Nov 24 11:08:11 UserName kernel: RDX: 00007ffc4fa101e0 RSI: 0000000040084b15 RDI: 000000000000001d
Nov 24 11:08:11 UserName kernel: RBP: 00007ffc4fa101e0 R08: 000000000000000d R09: 0000000000000001
Nov 24 11:08:11 UserName kernel: R10: 0000000000000001 R11: 0000000000000246 R12: 0000000040084b15
Nov 24 11:08:11 UserName kernel: R13: 000000000000001d R14: 00005624845a63f0 R15: 00007f7dc004c180
Nov 24 11:08:11 UserName kernel: </TASK>
Nov 24 11:08:11 UserName kernel: ---[ end trace 0000000000000000 ]---
Nov 24 11:08:11 UserName kernel: BUG: unable to handle page fault for address: 0000000000035080
Nov 24 11:08:11 UserName kernel: #PF: supervisor write access in kernel mode
Nov 24 11:08:11 UserName kernel: #PF: error_code(0x0002) - not-present page
-- Boot 5eec34d91fea46b993bddcd8e34d89f3 --
I realize you probably didn’t get the help you wanted with this thread
https://bbs.archlinux.org/viewtopic.php?id=290579
however just posting a part of a journal with out giving any other information is not going to help you resolve your issue so you will either get answers such as the one in the link or you wont get any.
how about post some information about your system. What caused you to need to look at the journal output What Distro are you actually Using?
posting a journal without any real explanation of what is going on is like putting a love letter in a bottle putting in the ocean and wonder why the girl next door hasn’t responded.
I have posted about pretty much everything already here:
but I didnt get any replies that enabled progress in finding a solution. Neither did posting in the LO forums get any reactions at all. And Arch Linux forum just kicked me out cause Im not running pure arch. But ill post it here again.
Hi, I have a very peculiar problem, every time I open any .odt, .docx, .pdf with either Writer or Draw they show the little floating box with the loading bar. But then at the half way point my system completely freezes. Then killing it via hard reset is necessary to be able to even restart.
I have tried different files, opened them with Okular, Onlyoffice etc., its only Libreoffice that completely freaks out. I only have one extension installed, that enables better image export. (ancient I know but it still works and the in built functionality is too bad for my needs: https://extensions.libreoffice.org/en/extensions/show/export-as-images).
I have uninstalled fresh and moved to still, then back again, the error persists nonetheless.
Starting in safemode kinda works, I can start and use the Programs, Writer etc. but when I try to apply a full factory reset, it just freezes again. Tried twice, it just clears the contents of that menu window but the borders remain. Then it either freezes that Window or my System.
Trying to open Writer/Draw without any document shows nothing, Writer shortly displays the blue icon in the taskbar but that soon vanishes. The process soffice.bin then appears as a zombie process in Ksysguard.
Shutting my System down while it wasnt frozen but LibreOffice was unresponsive, takes a long time.
It gets stuck at the step of
“A stop job is running for User Manager for UID 1000 (x/x mins)” for five to ten minutes.
Also
“systemd-shutdown[1]: waiting for process 69694 (soffice.bin)” takes a while to finish.
Changing users doesnt really help, the loading banner reaches 100% and it doesnt freeze anything, but the Program doesnt actually open.
Deleting the LO folder in .config/ also doesnt help.
Starting in safe-mode without acceleration works, but it also works fine with acceleration. Also removing the extension doesnt help.
I however cant use it normally at all.
Either I open a document with LO and it freezes/crashes my System, or I open LO by itself and it just dies in the background/doesnt start and freezes the process to complete unresponsiveness. *Though now it also crashes when started by itself.
Im on the latest updates available for LO and my system (EndeavourOS, KDE Plasma 5). [Ryzen 5900X - 64GB RAM - RX 6800XT - 200GB free space on the home disk]
Thanks, any help is greatly appreciated.
please keep only one thread open per topic.
starting a new topic when you already have a thread open for the issue isn’t going to solve the issue. please keep the topic in one place.
Closing this thread due to double posting to continue react to this thread:
