Ever since I changed my GPU from a GTX 1650 to a Radeon 6600XT I’ve been experiencing random freezes, I don’t know if the problem is the GPU because it seems to work well on windows, and it happens very randomly for example I can be playing something like CP2077 or using Unreal Engine and everything is fine but I could be doing random stuff like writing a document on LibreOffice or watching a youtube video and it starts to stutter and freezing. This freezes only last for a few seconds, I did uninstall the nvidia drivers but it didn’t help, and all the disks seem to be healthy according to crystaldisk on windows. Also I’m a noob in arch (I’ve been using previously POP OS and I wasn’t an expert in that either)
My specs
Kernel: 5.16.0-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=6bb7b559-7740-4080-bd85-32e37f1aa399 rw quiet loglevel=3
nowatchdog nvme_load=YES nvidia-drm.modeset=1
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Desktop Mobo: ASRock model: B450 Steel Legend
serial: <superuser required> UEFI: American Megatrends v: P3.50
date: 09/23/2020
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2400 high: 3600 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2276 2: 2104
3: 2135 4: 2193 5: 2196 6: 2193 7: 3600 8: 2183 9: 2089 10: 2112 11: 3591
12: 2130 bogomips: 86278
Vulnerabilities:
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v1
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
STIBP: conditional, RSB filling
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M]
vendor: Sapphire Limited driver: amdgpu v: kernel bus-ID: 0c:00.0
chip-ID: 1002:73ff class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-7.3:5 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: modesetting alternate: ati,fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.0x11.3") diag: 584mm (23")
OpenGL: renderer: AMD Radeon RX 6600 XT (DIMGREY_CAVEFISH DRM 3.44.0
5.16.0-arch1-1 LLVM 13.0.0)
v: 4.6 Mesa 21.3.4 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 0c:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
driver: snd_hda_intel v: kernel bus-ID: 0e:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Logitech HD Pro Webcam C920 type: USB
Device-4: Kingston HyperX QuadCast type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:2 chip-ID: 0951:16df
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.16.0-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: ASRock driver: r8169 v: kernel port: f000 bus-ID: 09:00.0
chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth:
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb v: 0.8 bus-ID: 1-3:2 chip-ID: 0a12:0001 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Local Storage: total: 3.07 TiB used: 1.81 TiB (58.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FP6256G
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: EDFM20.0
temp: 9.8 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Biostar model: S100-120GB
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 5.0 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate
model: ST2000LM003 HN-M201RAD size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0001 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MQ01ABD100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 3J scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 212.59 GiB (91.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 27.8 MiB (9.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 39.0 C
mem: 36.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 369 Uptime: 50m wakeups: 0 Memory: 31.28 GiB
used: 5.47 GiB (17.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1557 pacman: 1531 lib: 468 flatpak: 5
snap: 21 Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.11
other specs
-CPU Cooler Cooler Master ML120L V2
-Ram 2x 8gb Adata XPG Spectrix D50 3200 mhz + 2x 8gb G.Skill Aegis 3200mhz (everything is running at 2666mhz because it’s what my motherboard supports)
-GPU AMD Radeon 6600XT Sapphire Pulse (I use 2 1080p monitors and sometimes an HD TV)
-PSU Seasonic Focus GM-850
-Storage 1 m.2 nvme 240gb SSD TeamGroup MP33 (Eandeavor OS) + 1 Sata SSD Biostar 120gb (windows 11), 1 2tb Sata HDD for endeavor storage and 1tb HDD for Windows
