“Give up” may be too strong a phrase. But I’m just so used to SystemD over the years, I just felt more comfortable using it. If I were to stay SystemD-free, Artix would be where I’d land.
Tumbleweed is an excellent distro, I used it for over 8 years before switching to endeavouros
I can understand that. I’ve been going slow as I’m a new learner to manipulating services, but I’m keen on pursuing it because of the big difference in non-systemd setups. Quite enlightening and Artix runs well, I’ll give it that.
Yeah, FINALLY settled, for the next two weeks! ![]()
What you need on that Thinkpad is LFS. Honestly.
It will keep you busy for the foreseeable future.
AND give the rest of us a well-needed respite ![]()
That’s where I’m at. I love using a runit (or whatever) environment but I can’t navigate it in terminal. systemctl I know really well and and comfortable navigating it. That simple.
If I was going to go to a systemd-free environment, I was dazzled by this indy out of Malaysia called Venom. Best thing I had on my Ventoy for a long time.
OK good luck with Suse. edit/sp
I loved SuSE, my last version of that was 9.0. That was before Novell had bought them. They had a 2-2.5 inch thick user manual! I tried OpenMandriva once, but it seems to have nVidia hardware. It installed no problem on my AMD CPU/GPU laptop, but on my AMD/nVidia laptop, it gave me the bird! LOL
There is suffering involved? Seriously?
My bet is 4 weeks. My 20 on the line.
But hopefully you’re on a different DE than your standard? That’s another adventure.
It’s highly rated on Distrowatch (for whatever that’s worth). I’ll check it out on Ventoy.
That’s a rare one that I haven’t heard of…must look into. Thanks ;0
Realizing that Tumbleweed didn’t tumble as expected either. ![]()
Tumbleweed is underrated. It’s probably the best rpm-based distro IMO.
@UncleSpellbinder
I think you should try Omarchy on that laptop.
Not for me so far. Smooth as silk at the moment. And updates have been very quick.
