You haven’t let your Linux hang around in a bad crowd?
Pudge
It does…
/usr/bin/sudo. Although, it isn’t sudo because it also happens with pkexec
I don’t see anything abnormal and it happens with a new clean user
Not that I can find
But not with root? Strange.
One of the strangest issues I’ve ever seen!
mon keys aren’t attracted to root!.
OK, let’s dive deep.
Install strace and trace the execution, e.g.
sudo strace -f pacman -S ....
(-f means “follow” so it will follow any forked subprocesses)
It will output a lot of text so you will want to pipe to grep or narrow down the system calls with e.g.
sudo strace -f -e open pacman -S ....
which limits it to the open syscall. Others may be useful, like stat, statx, read, and write. It’s going to take a little while to find the specific call, but this should show the exact execution trace and identify exactly where the monkey is coming from.
For example:
$ sudo strace -f -eopen,stat,statx,access pacman -Syu
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
stat("/", {st_mode=S_IFDIR|0755, st_size=284, ...}) = 0
stat("/var/lib/pacman/", {st_mode=S_IFDIR|0755, st_size=18, ...}) = 0
access("/var/lib/pacman/sync/core.db", R_OK) = 0
access("/var/lib/pacman/sync/core.db.sig", R_OK) = -1 ENOENT (No such file or directory)
access("/var/lib/pacman/sync/extra.db", R_OK) = 0
access("/var/lib/pacman/sync/extra.db.sig", R_OK) = -1 ENOENT (No such file or directory)
access("/var/lib/pacman/sync/community.db", R_OK) = 0
access("/var/lib/pacman/sync/community.db.sig", R_OK) = -1 ENOENT (No such file or directory)
access("/var/lib/pacman/sync/multilib.db", R_OK) = 0
access("/var/lib/pacman/sync/multilib.db.sig", R_OK) = -1 ENOENT (No such file or directory)
access("/var/lib/pacman/sync/endeavouros.db", R_OK) = 0
access("/var/lib/pacman/sync/endeavouros.db.sig", R_OK) = -1 ENOENT (No such file or directory)
access("/var/lib/pacman/sync/repo-ck.db", R_OK) = 0
access("/var/lib/pacman/sync/repo-ck.db.sig", R_OK) = -1 ENOENT (No such file or directory)
access("/etc/pacman.d/gnupg/pubring.gpg", R_OK) = 0
access("/etc/pacman.d/gnupg/trustdb.gpg", R_OK) = 0
access("/home/jonathon/perl5/perlbrew/bin/gpgconf", X_OK) = -1 ENOENT (No such file or directory)
access("/home/jonathon/bin/gpgconf", X_OK) = -1 ENOENT (No such file or directory)
access("/usr/local/bin/gpgconf", X_OK) = -1 ENOENT (No such file or directory)
access("/usr/bin/gpgconf", X_OK) = 0
access("/usr/bin/gpgconf", F_OK) = 0
strace: Process 460917 attached
strace: Process 460918 attached
[pid 460917] +++ exited with 0 +++
[pid 460916] --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=460917, si_uid=0, si_status=0, si_utime=0, si_stime=0} ---
[pid 460918] access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
[pid 460918] access("/etc/gcrypt/fips_enabled", F_OK) = -1 ENOENT (No such file or directory)
[pid 460918] stat("/run/user/0", 0x7ffc01e92d50) = -1 ENOENT (No such file or directory)
[pid 460918] stat("/var/run/user/0", 0x7ffc01e92d50) = -1 ENOENT (No such file or directory)
[pid 460918] +++ exited with 0 +++
strace: Process 460919 attached
strace: Process 460920 attached
[pid 460919] +++ exited with 0 +++
[pid 460916] --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=460919, si_uid=0, si_status=0, si_utime=0, si_stime=0} ---
[pid 460920] access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
[pid 460920] access("/etc/gcrypt/fips_enabled", F_OK) = -1 ENOENT (No such file or directory)
[pid 460920] access("/usr/bin/pinentry", F_OK) = 0
Here is what I think it the relevant output: https://pastebin.com/qNzMapGZ
Hopefully we don’t need the ~17,000 lines after that.
It does use the locate ‘updatedb’ for filename searching - but I don’t think impacts file content searches - and it still seems relatively quick.
I can’t remember if I had to install it, or if it came with EnOS - but it does’t take long either way! (nor does the sudo updatedb, or its GUI equivalent).
OK,
stat("/var/lib/pacman/local/", {st_mode=S_IFDIR|0755, st_size=1652, ...}) = 0
stat("/etc/localtime", {st_mode=S_IFREG|0644, st_size=2310, ...}) = 0
access("/var/lib/pacman/local/glibc-2.32-4/install", R_OK) = 0
access("/tmp/", F_OK) = 0
strace: Process 2106182 attached
[pid 2106182] access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
[pid 2106087] stat("/etc/localtime", {st_mode=S_IFREG|0644, st_size=2310, ...}) = 0
monkey
So, check the contents of /var/lib/pacman/local/glibc-2.32-4/install .
If that’s normal then we need to go deeper - you’ll have to try some other syscalls and e.g. check what is using read to read “monkey” from a file and/or write “monkey” to an output.
e.g.:
$ sudo strace -f -e write pacman -Syu
write(10, "\26\3\1\2\0\1\0\1\374\3\3\346\305:\202\341\227\332@\276\0204\207\301\356\306$jo\336\224\201"..., 517) = 517
write(1, "\33[0m", 4) = 4
write(3, "[2020-09-09T23:18:28+0100] [PACM"..., 65) = 65
write(2, "\33[1;33mwarning: \33[0m", 20warning: ) = 20
The first number tells us the device handle, and while it’s still open:
$ sudo lsof -p $PACMAN_PID
pacman 35786 root 1u CHR 136,0 0t0 3 /dev/pts/0
pacman 35786 root 2u CHR 136,0 0t0 3 /dev/pts/0
pacman 35786 root 3w REG 0,56 12872787 3378 /var/log/pacman.log
pacman 35786 root 10u IPv6 395060 0t0 TCP localhost:60844->server6.alpix.eu:https (ESTABLISHED)
will tell us which handle maps to which device.
Remember that you can use CTRL+Z to background (and pause) a process when you see something interesting, and fg to resume it.
If you want to go still deeper, then gdb will be the next step.
Man, these are some subterranean monkeys…
Perhaps we’ll need to put them on display when they finally located - a zoo next to the wiki?
What’s in /usr/share/libalpm/scripts ?
There’s always one bad monkey in the group.
But which one ???
OK, this seems relevant:
[pid 2225925] read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 `\1\0\0\0\0\0"..., 832) = 832
[pid 2225925] read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\22\0\0\0\0\0\0"..., 832) = 832
[pid 2225925] read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220\202\2\0\0\0\0\0"..., 832) = 832
[pid 2225925] read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 p\1\0\0\0\0\0"..., 832) = 832
[pid 2225925] read(3, "# GNU libc iconv configuration.\n"..., 8192) = 8192
[pid 2225925] read(3, "\tISO-IR-110//\t\tISO-8859-4//\nalia"..., 8192) = 8192
[pid 2225925] read(3, "DIC-ES//\nalias\tEBCDICES//\t\tEBCDI"..., 8192) = 8192
[pid 2225925] read(3, "\t\tIBM863//\nalias\tOSF1002035F//\t\t"..., 8192) = 8192
[pid 2225925] read(3, "UJIS//\t\t\tEUC-JP//\nmodule\tEUC-JP/"..., 8192) = 8192
[pid 2225925] read(3, "O_5427-EXT//\nalias\tISO_5427EXT//"..., 8192) = 8192
[pid 2225925] read(3, "112//\t\tINTERNAL\t\tIBM1112\t\t1\nmodu"..., 8192) = 7201
[pid 2225925] read(3, "", 8192) = 0
[pid 2225925] read(3, "#\n# /etc/bash.bashrc\n#\n\n# If not"..., 618) = 618
[pid 2225925] read(3, "echo monkey\n", 12) = 12
@jonathon, maybe I am reading this wrong but I don’t see anything to indicate which file maps to the above. My fear would be it was closed before I had a chance to stop the process
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
pacman 2222573 root cwd DIR 0,26 22 34 /
pacman 2222573 root rtd DIR 0,26 22 34 /
pacman 2222573 root txt REG 0,26 145344 723340 /usr/bin/pacman
pacman 2222573 root DEL REG 0,26 1228567 /usr/lib/locale/locale-archive
pacman 2222573 root DEL REG 0,26 1227733 /usr/lib/libresolv-2.32.so
pacman 2222573 root mem REG 0,26 22200 727651 /usr/lib/libkeyutils.so.1.10
pacman 2222573 root mem REG 0,26 55264 1281250 /usr/lib/libkrb5support.so.0.1
pacman 2222573 root mem REG 0,26 1574704 18025 /usr/lib/libunistring.so.2.1.0
pacman 2222573 root mem REG 0,26 22216 1024642 /usr/lib/libattr.so.1.1.2448
pacman 2222573 root DEL REG 0,26 1221707 /usr/lib/libdl-2.32.so
pacman 2222573 root DEL REG 0,26 1221741 /usr/lib/libpthread-2.32.so
pacman 2222573 root mem REG 0,26 18112 1025036 /usr/lib/libcom_err.so.2.1
pacman 2222573 root mem REG 0,26 194456 1281227 /usr/lib/libk5crypto.so.3.1
pacman 2222573 root mem REG 0,26 936256 1281247 /usr/lib/libkrb5.so.3.3
pacman 2222573 root mem REG 0,26 344088 1281221 /usr/lib/libgssapi_krb5.so.2.2
pacman 2222573 root mem REG 0,26 585320 926575 /usr/lib/libssl.so.1.1
pacman 2222573 root mem REG 0,26 71272 729990 /usr/lib/libpsl.so.5.3.3
pacman 2222573 root mem REG 0,26 256144 812 /usr/lib/libssh2.so.1.0.1
pacman 2222573 root mem REG 0,26 128696 23532 /usr/lib/libidn2.so.0.3.7
pacman 2222573 root mem REG 0,26 173848 970800 /usr/lib/libnghttp2.so.14.20.0
pacman 2222573 root mem REG 0,26 100096 16486 /usr/lib/libz.so.1.2.11
pacman 2222573 root mem REG 0,26 74440 16606 /usr/lib/libbz2.so.1.0.8
pacman 2222573 root mem REG 0,26 132784 17179 /usr/lib/liblz4.so.1.9.2
pacman 2222573 root mem REG 0,26 853696 932973 /usr/lib/libzstd.so.1.4.5
pacman 2222573 root mem REG 0,26 157456 1095508 /usr/lib/liblzma.so.5.2.5
pacman 2222573 root mem REG 0,26 190128 21662 /usr/lib/libexpat.so.1.6.11
pacman 2222573 root mem REG 0,26 38704 1024682 /usr/lib/libacl.so.1.1.2253
pacman 2222573 root DEL REG 0,26 1221713 /usr/lib/libm-2.32.so
pacman 2222573 root mem REG 0,26 2982648 926355 /usr/lib/libcrypto.so.1.1
pacman 2222573 root mem REG 0,26 583856 723551 /usr/lib/libcurl.so.4.6.0
pacman 2222573 root mem REG 0,26 153560 727800 /usr/lib/libgpg-error.so.0.30.0
pacman 2222573 root mem REG 0,26 79776 26478 /usr/lib/libassuan.so.0.8.3
pacman 2222573 root mem REG 0,26 322128 1127845 /usr/lib/libgpgme.so.11.23.0
pacman 2222573 root DEL REG 0,26 1227728 /usr/lib/libc-2.32.so
pacman 2222573 root mem REG 0,26 788312 121404 /usr/lib/libarchive.so.13.4.3
pacman 2222573 root mem REG 0,26 223512 723353 /usr/lib/libalpm.so.12.0.2
pacman 2222573 root DEL REG 0,26 1227717 /usr/lib/ld-2.32.so
pacman 2222573 root 0u CHR 136,1 0t0 4 /dev/pts/1
pacman 2222573 root 1u CHR 136,1 0t0 4 /dev/pts/1
pacman 2222573 root 2u CHR 136,1 0t0 4 /dev/pts/1
pacman 2222573 root 3w REG 0,26 1270856 642 /var/log/pacman.log
pacman 2222573 root 4w REG 0,26 0 1201784 /var/lib/pacman/db.lck
pacman 2222573 root 5r DIR 0,54 102 2 /home/evan
pacman 2222573 root 6u unix 0x0000000026568c7e 0t0 1767239 type=STREAM
Bingo.
Now it’s a case of finding which file has echo monkey in it. Maybe something related to /etc/bash.bashrc somewhere along the line…
I’m trying to find something with # GNU libc iconv configuration in it as that would seem obvious, but I haven’t found it yet.
Yup, if it’s not present then it was already closed (doing this in gdb lets you step through one call at a time, and that takes ages).
Probably /usr/lib/gconv/gconv-modules but there are no monkeys in it.
That make sense, looking again, this bit shows the file has 0 bytes read, so the /etc/bash.bashrc is in a different file.
The monkeys just jumped to another tree. ![]()
Did you use a filter wider than just -o read here? If you use -o open,stat,access,read it might point to a file.
I noticed that the output didn’t have any open calls. A little research revealed that openat is what is needed.
That produced this:
[pid 2316086] openat(AT_FDCWD, "/root/.bashrc", O_RDONLY) = 3
[pid 2316086] read(3, "echo monkey\n", 12) = 12
Which then led to this:
$ sudo cat /root/.bashrc
echo monkey
Next came this:
$ sudo rm /root/.bashrc
Finally we have:
$ /usr/bin/yay -S glibc
warning: glibc-2.32-4 is up to date -- reinstalling
resolving dependencies...
Packages (1) glibc-2.32-4
Total Installed Size: 46.16 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n]
(1/1) checking keys in keyring [#######################################################] 100%
(1/1) checking package integrity [#######################################################] 100%
(1/1) loading package files [#######################################################] 100%
(1/1) checking for file conflicts [#######################################################] 100%
:: Processing package changes...
(1/1) reinstalling glibc [#######################################################] 100%
Generating locales...
en_US.UTF-8... done
Generation complete.
(1/5) Reloading system manager configuration...
(2/5) Creating temporary files...
(3/5) Arming ConditionNeedsUpdate...
(4/5) Restarting cronie for libc upgrade...
(5/5) Updating the info directory file...
Thanks @jonathon!
The monkeys have been found!
So, any reason your root .bashrc was echo-ing monkey? Is it something you added while testing something?
You know what happens when you cage a monkey!
Are you saying that doesn’t come in normally with the install? ![]()
Well, I am sure there was a reason. It probably wasn’t a good reason though. It has been doing it for quite a while now so I have long since forgotten whatever I was trying to test with that. ![]()
The most interesting part is that root’s shell isn’t set to bash which is why it worked when you logged in as root.
