yay -Syu
[sudo] password for pol:
:: Synchronizing package databases…
core is up to date
extra is up to date
community is up to date
multilib is up to date
endeavouros is up to date
:: Starting full system upgrade…
:: Replace crda with core/wireless-regdb? [Y/n] y
resolving dependencies…
looking for conflicting packages…
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: wireplumber and pipewire-media-session are in conflict
→ error installing repo packages
Let it replace pipewire-media-session withwireplumber.
Try this:
sudo pacman -Rdd pipewire-media-session
sudo pacman -Syu wireplumber
Total Download Size: 1104.32 MiB
Total Installed Size: 4270.33 MiB
Net Upgrade Size: 33.93 MiB
:: Proceed with installation? [Y/n]
Its normally?
Seems like it was a while ago you updated your system hence the size of the update.
Y and enter if you want to go on updating your system.
Thanks
Please consider checking the solution box under the post which gave you the solution for this issue:
The forum software will then consider the topic as solved and other users who might have similar issue will find the solution more easily.
