I can’t play youtube in chrome,the video display fails to load.I thought it was because when installing bluetooth, the dependencies conflicted then I removed some dependencies.How should i solve this problem?
What specifically did you remove?
Check your pacman log in /var/log/pacman.log
, or the output of paclog
(if it’s installed). Don’t just copy-paste the whole thing, look for the specific time you started removing packages.
thanks, I install pipewire-media-session and the issue is be solved.
Check out this post from me a little while ago. Had similar issues, had to switch from pulse audio to pipewire.
