GNU nano 8.4 1
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Fri 2025-06-13 07:27:26 CEST; 36min ago
Invocation: b12d187227d44ff7a5f05f2e39eb8299
Docs: man:bluetoothd(8)
Main PID: 13237 (bluetoothd)
Status: “Running”
Tasks: 1 (limit: 4651)
Memory: 1.4M (peak: 2.2M, swap: 208K, swap peak: 208K, zswap: 31.4K)
CPU: 150ms
CGroup: /system.slice/bluetooth.service
└─13237 /usr/lib/bluetooth/bluetoothd
Jun 13 07:40:00 pal bluetoothd[13237]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/aptx_ll_d>
Jun 13 07:40:00 pal bluetoothd[13237]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/faststream
Jun 13 07:40:00 pal bluetoothd[13237]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/faststrea>
Jun 13 07:40:00 pal bluetoothd[13237]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSink/opus_05
Jun 13 07:40:00 pal bluetoothd[13237]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/opus_05
Jun 13 07:40:00 pal bluetoothd[13237]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSink/opus_05_dup>
Jun 13 07:40:00 pal bluetoothd[13237]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/opus_05_d>
Jun 13 07:41:44 pal bluetoothd[13237]: src/device.c:search_cb() 41:42:91:A5:8F:3E: error updating services: Devic>
Jun 13 07:43:30 pal bluetoothd[13237]: src/device.c:search_cb() 41:42:91:A5:8F:3E: error updating services: Devic>
Maybe because the headphones have Bluetooth 5.0 and the adapter has Bluetooth 2.0?Blueman first sees these headphones and then they disappear.Or maybe the Wi-Fi signal suppresses them? There are many very strong Wi-Fi signals nearby.
