do you try GNOME on Xorg session already ?
I just tried xorg and it worked for 10 minutes with only a few short freezes but then freezes completely again but i can move the mouse now while itâs frozen.
Ok now itâs working again so it freezes for a few minutes.
This is unusual?
Maybe odd edge case network r8168 issue?
@callj
Can you try idle=nomwait as a kernel parameter in the default grub command line and then update grub.
sudo nano /etc/default/grub
add here after quiet:
GRUB_CMDLINE_LINUX_DEFAULT=âquiet loglevel=3 nowatchdog nvme_load=YESâ
idle=nomwait
Then save with ctrl + o then enter
Exit Nano with ctrl + x
Then update grub with
Then reboot
The problem seems to have been fixed by the changes in grub the system is running without freezing so far. I donât understand what exactly the problem was, but the main thing is that it works. Many thanks to everyone who helped me.
So the idle=nomwait works then? Please mark it as solved if you find you arenât having anymore issues. If you find you still have issues you can open another thread.
Edit: If you want to leave the topic open until youâre sure thatâs fine also.
