So, I need to asign the Print Screen key for taking screenshot with Flameshot, and I don’t know if it’s this version of KDE being buggy, but I cannot assign it on Settings > Shortcuts > Custom Shortcuts. I keep clicking None button, but nothing happens after pressing any key:
KDE Plasma Version: 5.20.4
KDE Frameworks Version: 5.77.0
Qt Version: 5.15.2
Kernel Version: 5.10.3-arch1-1
I’m pretty sure it’s an issue in Plasma. I have the same issue on all my Endeavour machiens, along with Debian Bullseye (also on 5.20.4), and KDE Plasma (also on 5.20.4). If you have anything on an older version, you can go in, assign the keystroke, export it, and then import it, that’s how I’ve been getting around the problem.
Agreed on that, although for me it’s Ksnip. Spectacle is just…lacking. Why go through multiple applications to do simple annotations such as adding texts, arrows, highlights, etc? Flameshot/Ksnip adds this abilty so that you can take your screenshot and do extremely basic edits it quickly in 1 shot, rather than going from app to app.
And by the way, issue fixed! I have exported the shortcuts config from Kubuntu and now Print Screen key works after having imported it on Endeavour. Thanks @tlmiller76!
Mmm, so in my case the command I have to run for taking screenshots with Flameshot is flameshot gui, but if I type that on there, I don’t see anything like that
What you do to use the way Ringo found is go in and Create the “custom shortcuts” and set the command to use. THEN go into the “custom shortcuts service” in Shortcuts, find the custom shortcut you set, and set it there. Just tried it on Debian Bullseye and it does indeed work. Haven’t tested on Endeavour, but betting it would since every OS I was using had that issue.
Ohh alright, I get what you mean… I have just tried it on Endeavour and yes, it works, so it should work for everyone as well. That’s indeed better than exporting/importing.
