Hyprland not starting after system update
installing the AUR packages was something i tried to do earlier that bit me in the butt, was thinking right before you sent this of just uninstalling them. doing that right now. and thank you for the shell recommendation.
Small suggestion moving forward. It sounds like you are new at working in Arch base Linux and well there is so much choice. What I did when I started (and even now) when I was going to try something new:
  1. Check Sources like the (Arch Wik + EndeavourOS forums) to learn if there are recommendations on how to do something.
  2. Before I install any package, I check the project Github/Repo to see what the documentation looks like and what are the known bugs.
  3. I then write a plan how I intend to do the install and setup.
Most Importantly - do a sanity check. Take your plan and post it here in the forums discussing what you want to do. This way you avoid creating a mess in your environment.
We have some amazing people here @dalto @ddnn @anon24169379 @Scotty_Trees (so many experts who have cut their teeth). Better to get it right the first time.
p.s. I have found researching in AI is not a bad idea. But I talk to the experts with my plan in hand.
Example of a plan:
How exactly are you rebuilding the git packages? You need to make sure that every package is rebuilt in the correct order (which an AUR helper should handle) or it’s not going to work. You also need to exclude any installed Chaotic packages, which can very easily be linked to the old libraries (as hyprgraphics is, in your case).
