Hello everyone! I recently switched to Hyprland and for the most part, everything works perfectly. However, I’m having some trouble setting the correct monitor positions. I’ve read the documentation and from my understanding I’ve configured everything correctly.
So I have my external monitor above my laptop display. The external display works fine, and there’s no overlap or anything like that. My issue though, is that since Hyprland is seeing my external monitor at 1920x0 (horizontally shifted right), and my laptop display at 0x1080 (vertically shifted down) to move between displays I have use the top right corner (laptop) or the bottom left corner (external). To have Hyprland match my physical layout, my external monitor should be positioned at 0x0 (no shifting).
As you can see in my original post, I’ve set the position to be at 0x0, yet something isn’t translating correctly. At first I thought this was just a wayland issue, so I installed Plasma along with it’s wayland seesion. My monitors work exactly as I expect them to, meaning it’s a Hyprland issue.
