Hi - I have a hybrid graphics laptop and I am seeking to get the nvidia GPU working again as I am finding myself doing more video editing and using freecad.
I installed EOS 2-3 years ago and when I did that I also followed the instructions on the eos nvidia page for optimus-switch and eventually I had everything working. Now, I rarely had a need to use the nvidia gpu and did not keep up to date with it. I also installed optimus-indicator too.
I recently noted that optimus-switch was giving me systemd errors so I uninstalled it, although I still have the directories for both optimus-switch and optimus-indicator (which will not uninstall?) in my root directory.
As stated, I would like to start using my nvidia gpu again and I have the following questions that I would appreciate some guidance on:
- I already have nvidia drivers installed and the nvidia-install-dkms installed, can/should I also install nvidia-inst?
- can I simply remove the directories for optimus-switch and optimus-indicator and reinstall them to use following the instructions here and here?
- Is there a better way of doing this now that it has been a 2-3 years?
- any other helpful thoughts before I plow into this?
Below is my system specs per the output of ’ inxi -Fxxc0z | eos-sendlog
Thank you - all replies are appreciated.
Kernel: 6.1.12-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
Desktop: KDE Plasma v: 5.27.1 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Laptop System: ASUSTeK product: X510UNR v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X510UNR v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X510UNR.309 date: 05/14/2019
Battery:
ID-1: BAT0 charge: 23.8 Wh (100.0%) condition: 23.8/42.1 Wh (56.6%)
volts: 11.5 min: 11.5 model: ASUSTeK ASUS Battery serial: N/A
status: not charging
Info: quad core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Coffee Lake rev: A cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 1862 high: 2000 min/max: 400/4000 cores: 1: 2000 2: 2000
3: 2000 4: 900 5: 2000 6: 2000 7: 2000 8: 2000 bogomips: 32012
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9.5 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:5917
Device-2: NVIDIA GP108M [GeForce MX150] vendor: ASUSTeK driver: nvidia
v: 525.89.02 arch: Maxwell pcie: speed: 2.5 GT/s lanes: 4 bus-ID: 01:00.0
chip-ID: 10de:1d10
Device-3: IMC Networks VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:2 chip-ID: 13d3:5a07
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: intel,nvidia unloaded: fbdev,modesetting,vesa alternate: nouveau,nv
dri: i965 gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96
Monitor-1: eDP-1 mapped: eDP1 model: AU Optronics 0x21ed res: 1920x1080
dpi: 143 diag: 394mm (15.5")
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
Sound API: ALSA v: k6.1.12-arch1-1 running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-2: PulseAudio v: 16.1 running: yes
Sound Server-3: PipeWire v: 0.3.66 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
Bluetooth:
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-8:3 chip-ID: 8087:0a2b
Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
Local Storage: total: 1.14 TiB used: 147.03 GiB (12.6%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
speed: 6.0 Gb/s serial: <filter>
ID-2: /dev/sdb vendor: Micron model: 1100 MTFDDAV256TBN size: 238.47 GiB
ID-1: / size: 216.57 GiB used: 147.03 GiB (67.9%) fs: ext4 dev: /dev/dm-0
mapped: luks-d79f1908-622d-42c0-9c4d-2826c932ae51
ID-2: /boot/efi size: 299.4 MiB used: 452 KiB (0.1%) fs: vfat
dev: /dev/sdb1
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 mapped: luks-426759bb-6a5a-47d3-8a59-620196bc91e8
System Temperatures: cpu: 45.0 C pch: 36.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2700
Processes: 262 Uptime: 35m Memory: 15.51 GiB used: 5.28 GiB (34.0%)
Init: systemd v: 253 default: graphical Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1693 Shell: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
