Hi love Papirus icon pack
But dont like their folder icons
So iwant to replace Papirus default folder icons with arc folder icons
How can i do that?
How can i do that?
all icon names mostly got some type of names, but just copy a theme in .icons
try to replace respective icons… give a own name the folder and in index.theme
from there you start…its also easily to find it
create a new icon theme, just copy the papirus one and called it papirus-new (or whatever)
open the index.theme file and change the name there and change the inherit line to inherits=arc (or whatever the arc icon theme is called), then delete all the folder icons from this new theme
But i dont want all arc icons
Just icons for folders
Rest apps will use papirus
Wheb it inhirent arc it will fill the missing icons you removed of papirus
Ohk
Have you tried papirus-folders package before? It’s what I use with papirus-icons and love that I can change all the folder colors easily. Check it out here if you’re curious (it’s in the AUR btw):
Yes, i tried that
Just dont like Papirus folder icons in any color
Arc has cool folder icons
