Htop vs Screenfetch vs Neofetch vs System Monitor
who to believe/use??? :thinking: :thinking: :thinking:Screenshot_2019-12-07_15-30-15
$ sudo pacman -S hardinfo
HARD-INFO
Too ugly… is like system bench that​:grimacing:
Glances.
GLANCES
normal it looks like windows vista, ok I’m going out :rofl:
Gotop.
GOTOP
ALSI - ARCHEY3
TOP
[judd@judd ~]$ systemctl status
● judd
    State: running
     Jobs: 0 queued
   Failed: 0 units
    Since: Sat 2019-12-07 11:24:16 -03; 35min ago
   CGroup: /
           β”œβ”€user.slice
           β”‚ └─user-1001.slice
           β”‚   β”œβ”€user@1001.service
           β”‚   β”‚ β”œβ”€gvfs-goa-volume-monitor.service
           β”‚   β”‚ β”‚ └─2593 /usr/lib/gvfs-goa-volume-monitor
           β”‚   β”‚ β”œβ”€pulseaudio.service
           β”‚   β”‚ β”‚ β”œβ”€2501 /usr/bin/pulseaudio --daemonize=no
           β”‚   β”‚ β”‚ └─2537 /usr/lib/pulse/gsettings-helper
           β”‚   β”‚ β”œβ”€gvfs-daemon.service
           β”‚   β”‚ β”‚ β”œβ”€ 2456 /usr/lib/gvfsd
           β”‚   β”‚ β”‚ β”œβ”€ 2461 /usr/lib/gvfsd-fuse /run/user/1001/gvfs -f
           β”‚   β”‚ β”‚ β”œβ”€ 4276 /usr/lib/gvfsd-trash --spawner :1.3 /org/gtk/gvfs/exec_spaw/0
           β”‚   β”‚ β”‚ β”œβ”€16892 /usr/lib/gvfsd-network --spawner :1.3 /org/gtk/gvfs/exec_spaw/1
           β”‚   β”‚ β”‚ └─16907 /usr/lib/gvfsd-dnssd --spawner :1.3 /org/gtk/gvfs/exec_spaw/3
           β”‚   β”‚ β”œβ”€gvfs-udisks2-volume-monitor.service
           β”‚   β”‚ β”‚ └─2536 /usr/lib/gvfs-udisks2-volume-monitor
           β”‚   β”‚ β”œβ”€init.scope
           β”‚   β”‚ β”‚ β”œβ”€2389 /usr/lib/systemd/systemd --user
           β”‚   β”‚ β”‚ └─2390 (sd-pam)
           β”‚   β”‚ β”œβ”€gvfs-gphoto2-volume-monitor.service
           β”‚   β”‚ β”‚ └─4272 /usr/lib/gvfs-gphoto2-volume-monitor
           β”‚   β”‚ β”œβ”€at-spi-dbus-bus.service
           β”‚   β”‚ β”‚ β”œβ”€2474 /usr/lib/at-spi-bus-launcher
           β”‚   β”‚ β”‚ β”œβ”€2480 /usr/bin/dbus-daemon --config-file=/usr/share/defaults/at-spi2/accessibility.conf --nofork --print-address 3
           β”‚   β”‚ β”‚ └─2490 /usr/lib/at-spi2-registryd --use-gnome-session
           β”‚   β”‚ β”œβ”€dbus.service
           β”‚   β”‚ β”‚ β”œβ”€2448 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
           β”‚   β”‚ β”‚ β”œβ”€2483 /usr/lib/dconf-service
           β”‚   β”‚ β”‚ β”œβ”€2572 /usr/lib/mate-panel/wnck-applet
           β”‚   β”‚ β”‚ β”œβ”€2597 /usr/lib/goa-daemon
           β”‚   β”‚ β”‚ β”œβ”€4262 /usr/lib/goa-identity-service
           β”‚   β”‚ β”‚ β”œβ”€4286 /usr/lib/mate-applets/mate-geyes-applet
           β”‚   β”‚ β”‚ β”œβ”€4289 /usr/lib/mate-applets/mate-multiload-applet
           β”‚   β”‚ β”‚ β”œβ”€4290 /usr/lib/mate-sensors-applet/mate-sensors-applet
           β”‚   β”‚ β”‚ β”œβ”€4293 /usr/lib/mate-panel/clock-applet
           β”‚   β”‚ β”‚ β”œβ”€4294 /usr/lib/mate-applets/mateweather-applet
           β”‚   β”‚ β”‚ β”œβ”€4296 /usr/lib/mate-panel/notification-area-applet
           β”‚   β”‚ β”‚ └─4332 /usr/bin/mate-screensaver --no-daemon
           β”‚   β”‚ β”œβ”€gvfs-mtp-volume-monitor.service
           β”‚   β”‚ β”‚ └─4268 /usr/lib/gvfs-mtp-volume-monitor
           β”‚   β”‚ └─gvfs-afc-volume-monitor.service
           β”‚   β”‚   └─2588 /usr/lib/gvfs-afc-volume-monitor
           β”‚   └─session-1.scope
           β”‚     β”œβ”€  638 login -- judd
           β”‚     β”œβ”€ 2396 -bash
           β”‚     β”œβ”€ 2416 /bin/sh /usr/bin/startx
           β”‚     β”œβ”€ 2438 xinit /home/judd/.xinitrc -- /etc/X11/xinit/xserverrc :0 vt1 -keeptty -auth /tmp/serverauth.AriRME8p4x
           β”‚     β”œβ”€ 2439 /usr/lib/Xorg -nolisten tcp :0 vt1 -keeptty -auth /tmp/serverauth.AriRME8p4x
           β”‚     β”œβ”€ 2445 mate-session
           β”‚     β”œβ”€ 2488 /usr/lib/mate-settings-daemon/mate-settings-daemon
           β”‚     β”œβ”€ 2496 marco --sm-client-id 10c1e0815e31e4f70e156816623874659200000032240032
           β”‚     β”œβ”€ 2516 mate-panel --sm-client-id 10c1e0815e31e4f70e156816623874992700000032240033
           β”‚     β”œβ”€ 2541 caja --sm-client-id 10c1e0815e31e4f70e156816623875704300000032240034 --sm-client-state-file /home/judd/.config/session-state/caja-1575721767.desktop
           β”‚     β”œβ”€ 2554 mate-volume-control-status-icon
           β”‚     β”œβ”€ 2555 /usr/lib/mate-polkit/polkit-mate-authentication-agent-1
           β”‚     β”œβ”€ 2562 nm-applet
           β”‚     β”œβ”€ 2579 /usr/bin/python3 /usr/share/system-config-printer/applet.py
           β”‚     β”œβ”€ 2580 mate-maximus
           β”‚     β”œβ”€ 6513 /usr/lib/chromium/chromium
           β”‚     β”œβ”€ 6518 /usr/lib/chromium/chromium --type=zygote
           β”‚     β”œβ”€ 6520 /usr/lib/chromium/chromium --type=zygote
           β”‚     β”œβ”€ 6538 /usr/lib/chromium/chromium --type=gpu-process --field-trial-handle=17551723061467378146,15521785559116670568,131072 --gpu-preferences=KAAAAAAAAAAgAAAgA>
           β”‚     β”œβ”€ 6543 /usr/lib/chromium/chromium --type=utility --field-trial-handle=17551723061467378146,15521785559116670568,131072 --lang=es-419 --service-sandbox-type=ne>
           β”‚     β”œβ”€ 6664 /usr/lib/chromium/chromium --type=renderer --field-trial-handle=17551723061467378146,15521785559116670568,131072 --lang=es-419 --enable-auto-reload --n>
           β”‚     β”œβ”€71597 /usr/lib/chromium/chromium --type=renderer --field-trial-handle=17551723061467378146,15521785559116670568,131072 --lang=es-419 --enable-auto-reload --n>
           β”‚     β”œβ”€78488 /usr/lib/chromium/chromium --type=renderer --field-trial-handle=17551723061467378146,15521785559116670568,131072 --lang=es-419 --enable-auto-reload --n>
           β”‚     β”œβ”€78501 /usr/lib/chromium/chromium --type=utility --field-trial-handle=17551723061467378146,15521785559116670568,131072 --lang=es-419 --service-sandbox-type=au>
           β”‚     β”œβ”€96416 lxterminal
           β”‚     β”œβ”€96421 bash
           β”‚     β”œβ”€96424 systemctl status
           β”‚     └─96425 less
           β”œβ”€init.scope
           β”‚ └─1 /sbin/init splash
           └─system.slice
             β”œβ”€preload.service
             β”‚ └─384 /usr/bin/preload --foreground --verbose 1
             β”œβ”€haveged.service
             β”‚ └─341 /usr/sbin/haveged -w 1024 -v 1 --Foreground
             β”œβ”€systemd-udevd.service
             β”‚ └─343 /usr/lib/systemd/systemd-udevd
             β”œβ”€polkit.service
             β”‚ └─2526 /usr/lib/polkit-1/polkitd --no-debug
             β”œβ”€rtkit-daemon.service
             β”‚ └─2523 /usr/lib/rtkit-daemon
             β”œβ”€wpa_supplicant.service
             β”‚ └─1605 /usr/bin/wpa_supplicant -u
             β”œβ”€systemd-journald.service
             β”‚ └─342 /usr/lib/systemd/systemd-journald
             β”œβ”€colord.service
             β”‚ └─4337 /usr/lib/colord
             β”œβ”€org.cups.cupsd.service
             β”‚ └─4336 /usr/bin/cupsd -l
             β”œβ”€NetworkManager.service
             β”‚ └─380 /usr/bin/NetworkManager --no-daemon
             β”œβ”€upower.service
             β”‚ └─6663 /usr/lib/upowerd
             β”œβ”€udisks2.service
             β”‚ └─2542 /usr/lib/udisks2/udisksd
             β”œβ”€dbus.service
             β”‚ └─379 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
             └─systemd-logind.service
               └─633 /usr/lib/systemd/systemd-logind
