Sorry for my ignorance, I just new to pacman… what is the command to dowload deltas for the new release Cassini and how to check the release in the terminal? I didn’t find anything both in the EndeavourOs site and around the net.
Thanks in advance.
Thanks in advance.
EndeavourOS is a rolling release distribution so you don’t need to reinstall it to get the latest packages
Simply update your system with sudo pacman -Syu
Merci bien! Alors je l’ai dejà fait! Je n’avait pas compris comment function le ‘rolling release’!
(Thanks! So, I just did it!, I did’nt understood how ‘rolling release’ works until now!)
Names like “Cassini” refer to the version of the ISO release, not the installed system. The installed system does not have a version, it’s rolling release.
So, @erik is right, just keep your system updated, and you’ll be on the latest version.
However, the new ISO brought some new features, like soystemd boot and Dracut. Your installed system will not automatically switch over to those when you update (that’s actually a good thing, if you think about it for a few seconds). You can keep using the old systems, GRUB and mkinitcpio, that’s fine. Or you can manually switch to Dracut and soystemd boot.
