I’ve been using EndeavourOS KDE for a while now. The default display manager is SDDM.
Is there a way to change the display manager to lightDM?
Thanks
Thanks
Yes, you just need to install and configure lightdm with a greeter.
Then you can switch with:
sudo systemctl enable lightdm.service --force
You should be aware though that the lock screen is part of plasma so if you do this your lock screen will look different from the login screen.
Thanks, dalto
Naturally. I installed KDE alongside XFCE and stayed with the lightdm display manager. I didn’t realize that not using SDDM would be a disadvantage for me. You can easily switch between display managers in the Welcome application.
