I am having a little bit of a conundrum. Basically I have this kind of setup:
#!/bin/bash
if [ "$1" == "--on" ]; then
pyhton3 script.py --option a &
python3 script.py --option b &
elif [ "$1" == "--off" ]; then
#What do I put here to turn off the python scripts?
fi
I tried something like just pkill python, but that didn’t actually work properly, only closing the terminal that executed the script will close the python scripts properly.
I need to send the equivalent of CTRL+C to the python scripts running in the background, how can I do this?
I had to use SIGTERM instead of SIGINT, cuz nothing happened with SIGINT. But it doesn’t quite work.
One of them closes properly, the other one doesn’t, and to close the other one i have to close the terminal which is the behavior i’m trying to get past.
This behavior isn’t making any sense to me.
EDIT: I get an error, on the terminal that ran the script when one of them fails to close, a python error. It only happens sometimes.
EDIT2: Using SIGKILL instead got rid of the error problem. Gonna mark your solution as the answer, thanks for the help!
SIGKILL can be rather brutal. If these are your own Python scripts, I’d tend to implement a signal handler, so your Python code could react to it and gracefully shut down.
It’s not actually my own, but it’s also kinda unnecessary in this case because what the code does is send a signal over bluetooth to the target devices every 20 seconds, and the point of stopping the script is to stop that signal from being sent (which lets the devices go to sleep).
But thanks for the input, I’ll keep it in mind if I write any python scripts of my own
