I have Motivewave (stock market program) installed, last update went smoothly during a PARU update, but now I get this:
==> Making package: motivewave 6.6.3-1 (Tue 27 Dec 2022 08:18:40 PM CST)
==> Checking runtime dependencies…
==> Checking buildtime dependencies…
==> Retrieving sources…
→ Found motivewave-6.6.3.deb
==> Validating source files with sha512sums…
motivewave-6.6.3.deb … Passed
==> Removing existing $srcdir/ directory…
==> Extracting sources…
→ Extracting motivewave-6.6.3.deb with bsdtar
==> Sources are ready.
motivewave-6.6.12-1: parsing pkg list…
==> Making package: motivewave 6.6.3-1 (Tue 27 Dec 2022 08:18:41 PM CST)
==> WARNING: Using existing $srcdir/ tree
==> Removing existing $pkgdir/ directory…
==> Entering fakeroot environment…
==> Starting package()…
bsdtar: Error opening archive: Failed to open ‘data.tar.xz’
==> ERROR: A failure occurred in package().
Aborting…
error: failed to build ‘motivewave-6.6.12-1’:
error: packages failed to build: motivewave-6.6.12-1
[mark@mark-optiplex9020 ~]$
I looked at getting a login to aurweb, but really I don’t have the credentials for all the prompts or info I would require to do that. The maintainer won’t get a lot of feedback, because only a few people ever download it. It’s been broken since it was put out there 3 days ago.
Alternatively, maybe is there a way to get paru or yay to not try to update it at all? If I have a working copy, maybe it’s more efficient to leave it at the current version.
And then extract the data.tar.zst from the .deb file. After that, try to run the command bsdtar -xf on the data.tar.zst file to see what error messages are returned.
[mark@mark-optiplex9020 Downloads]$ ls -l
total 174296
-rw-r–r-- 1 mark mark 510 Dec 19 16:08 control.tar.zst
-rw-r–r-- 1 mark mark 89230727 Dec 19 16:08 data.tar.zst
-rw-r–r-- 1 mark mark 4 Dec 19 16:08 debian-binary
-rw-r–r-- 1 mark mark 89231430 Dec 27 21:00 motivewave_6.6.12_amd64.deb
[mark@mark-optiplex9020 Downloads]$ bsdtar -xf data.tar.zst
Which is strange, because the latest version is supposed to be 6.6.12-1. That was probably the cause of those errors.
Looking at these lines, one could get some clues as to why the call to bsdtar failed. The file downloaded is motivewave-6.6.3.deb and if the contents are extracted, the data.tar.xz file probably resides in the motivewave-6.6.3/ directory.
It could be that the version mismatch prevents the shell from locating the data.tar.xz file. If the shells looks for the tar.xz file in the motivewave-6.6.12/ directory instead of the motivewave-6.6.3/ directory, it probably won’t be able to find the data.tar.xz file because the directory motivewave-6.6.12/ doesn’t exist. The extracted directory is motivewave-6.6.3, not motivewave-6.6.12
In other words, the person who wrote the PKGBUILD probably messed up?
That being said no one supports partial updates, and you should literally always avoid it. It’s the fastest way to break your system and no one will help you fix it since you shouldn’t do it.
But, it’s your computer, and that’s up to you, and it can be done.
It’s going to freeze at some point anyway, because I’m not going to pay for the yearly updates to this program over time through perpetuity… Since the update failed, I’m assuming that nothing really changed.
It’s an Elliott Wave program, and the updates are just features that make it a better trading platform, but I don’t use it for that.
Hoo boy. I’ve been in contact with the maintainer and I have sent copies of both yours and pebcak’s and anthony93’s analysis to him, and he doesn’t understand it.
He’s had me rerun paru, but the installation fails still showing involvement of both versions of motivewave as before, he really hasn’t changed anything. Yet he claims he’s installed it on his own laptop, so it’s all good.
What I get is this:
==> Making package: motivewave 6.6.3-1 (Wed 28 Dec 2022 11:53:10 AM CST)
==> Making package: motivewave 6.6.3-1 (Wed 28 Dec 2022 11:53:12 AM CST)
Aborting…
Looks like it’s a little different, but both versions are still referenced.
I might still just turn off the updates on this package, The maintainer means well, but he’s not at you guy’s knowledge level. Just sayin’.
