Hello lovely Endeavour community,
I’m wondering if someone can help guide me with shrinking the size of my swap partition?
I am much more comfortable with ext4 file systems but decided to be daring and try something new with btrfs. Might be in over my head.
I’ve been reading previous posts here and on the Arch Wiki; finding a lot about creating a swap file & swap partition, but have not come across any definitive solution for just shrinking the swap I accidentally made way too big.
Any assistance or suggestions for further reading are greatly appreciated!
Some info that might be helpful:
- I don’t ever use hibernate
- I have never used the full capacity of RAM
- I don’t really run any RAM-hungry programs
File system info:
[saturn@deepthought ~]$ lsblk -a
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 931.5G 0 disk
├─sda1 8:1 0 300M 0 part /boot/efi
├─sda2 8:2 0 897G 0 part /var/log
│ /var/cache
│ /home
└─sda3 8:3 0 34.2G 0 part [SWAP]
[saturn@deepthought ~]$ sudo btrfs subvolume list /
ID 256 gen 668869 top level 5 path @
ID 257 gen 668870 top level 5 path @home
ID 258 gen 668813 top level 5 path @cache
ID 259 gen 668870 top level 5 path @log
ID 260 gen 26 top level 256 path var/lib/portables
ID 261 gen 27 top level 256 path var/lib/machines
[saturn@deepthought ~]$ sudo fdisk -l
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Samsung SSD 870
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 85831B9A-5884-CD42-AC13-D953579443E7
Device Start End Sectors Size Type
/dev/sda1 4096 618495 614400 300M EFI System
/dev/sda2 618496 1881805571 1881187076 897G Linux filesystem
/dev/sda3 1881805572 1953520064 71714493 34.2G Linux swap
Let me know if any other details are required. And thanks in advance!!
