How to setup automatic suspend - battery settings in i3wm
How do you set up your laptop to suspend in i3wm?
Usually in xfce I do it in system settings under battery settings. I like it to suspend automatically after 20 min unused on battery. Thanks for any inputs/ideas!
Take a look at logind (/etc/systemd/logind.conf):
thanks for the tip!
HandlePowerKey=hibernate
#HandleSuspendKey=suspend
#HandleHibernateKey=hibernate
HandleLidSwitch=suspend
HoldoffTimeoutSec=30s
IdleAction=hybrid-sleep
IdleActionSec=30min
can use this also in config file
exec --no-startup-id xautolock -time 60 -locker "systemctl suspend"
can set the timer as you want
has to install xautolock first
I like this one, will try it! :+1:
Absolutely works. :pray:
