Device: 0 Name: NVIDIA Corporation GA104 [GeForce RTX™ 3060 Ti Lite Hash Rate] Default: yes Discrete: yes Environment: __GLX_VENDOR_LIBRARY_NAME=nvidia __NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only VK_LOADER_DRIVERS_SELECT=*nvidia* Device: 1 Name: Intel Corporation Raptor Lake-S GT1 [UHD Graphics 770] Default: no Discrete: no Environment: DRI_PRIME=pci-0000_00_02_0 VK_LOADER_DRIVERS_SELECT=*intel*
how do i set the default to my non discrete gpu?
BOOT_IMAGE=/@/boot/vmlinuz-linux root=UUID=668ae62f-bac3-41df-9202-2bb9ea2af4dd rw rootflags=subvol=@ nowatchd og nvme_load=YES loglevel=3
and grub, im most familiar with grub
switcheroo-control.service - Switcheroo Control Proxy service Loaded: loaded (/usr/lib/systemd/system/switcheroo-control.service;enabled; preset: disabled) Active:active (running)since Tue 2026-05-05 13:16:03 CDT; 24min ago Invocation: c12651f7261647c3911f84503385c55c Main PID: 1351 (switcheroo-cont) Tasks: 4 (limit: 76521) Memory: 1.2M (peak: 2.7M) CPU: 34ms CGroup: /system.slice/switcheroo-control.service └─1351 /usr/lib/switcheroo-control May 05 13:16:03 EOSWS-R121 systemd[1]: Starting Switcheroo Control Proxy service... May 05 13:16:03 EOSWS-R121 systemd[1]: Started Switcheroo Control Proxy service.
dracut.conf.d has 4 files, eos_intel_i915.conf, eos_nvidia_open.conf, eos-defaults.conf, and resume.conf, none of which contain anything pertaining to this(one line each)
eos-dracut is empty and the other file doesnt exist
By the way, have you looked into your BIOS settings to see if there is any setting which could explain the fact that your dGPU takes precedence over your iGPU?
