How to run commands from a shell script?
Hello, I am trying to make a crontab schedule for weekly system update (yay). And the crontab needs the shell script to run the command. How do it make the command run from the shell script?
A shell script is nothing but a list of shell commands. So, a simple (and quite pointless) shell script that runs yay would be:
#!/bin/sh
yay
In general, however, it is not true that Cron needs a shell script. Any executable will do.
Just a warning: do not try to automate updates on EndeavourOS (or any other derivation of Arch Linux). Manual intervention is often necessary and attempting to automate that will sooner or later create problems for you.
Don’t do this. On an Arch-based distro, updates need manual intervention. Automating them is a bad idea.
