Seems I’ve messed up my original EOS .bashrc. Even though I did save a .bashrc.bak copy it is not the original after new install.
Thanks
Did you take a look in /etc/skel/.bashrc
Thanks!
Actually I figured it out.
For some reason after updating to kernel 5.10 the theme on Yakuake that I use (Solarized) stopped showing my nano syntax highlighting. I’ve been fussing with it trying to configure the nanorc file and such. Just now got a bright idea to see if a plain Konsole would show any difference and BANG! It was the (Solarized) theme in Yakuake causing the problem.
new file here:
https://raw.githubusercontent.com/endeavouros-team/EndeavourOS-ISO/main/airootfs/root/endeavouros-skel-liveuser/src/etc/skel/.bashrc
I believe this can be marked as a solution for anyone in similar scenario in future. Don’t you @tulambin?
I just installed EOS and found that my .bashrc was overwritten. I had a copy and called the overwriter EOS.bashrc in case I need something from it later.
