How to recover a lost VeraCrypt Volume?
On a hard disk I some ext4, btrfs and a encrypted VeraCrypt (Standard VeraCrypt Volume).
But I mistakenly wiped the hard disk partition table. Using testdisk I was able to recover other ext4 and btrfs partitions without data loss.
But how do I recover the VeraCrypt volume? It is currently sitting as unallocated in the KDE Partition Manager. I do have the password.
Where can I get some help regarding this?
DISCLAIMER: THIS WAS GENERATED BY AN AI CHATBOT.
USE THE LINKS IT HAS CITED TO DO YOUR OWN RESEARCH.
I gave the chatbot the entire body of your post to have it generate this answer.
The Query: https://www.perplexity.ai/search/on-a-hard-disk-i-some-ext4-btr-OE5ljCKEQ2OD_wxfOU5oFg
To make it more specific to you, you could add “Arch Linux” to your query.
To recover your VeraCrypt volume after accidentally wiping the partition table, follow these steps:
Steps for Recovery
  1. Do Not Write New Data: Ensure that no new data has been written to the disk since the partition table was wiped. This is crucial to avoid overwriting any data that might still be recoverable.
  2. Use TestDisk:
    • Run TestDisk: Start TestDisk and select the affected hard disk.
    • Select None for Partition Type: When prompted for the partition type, select None to allow TestDisk to search for lost partitions.
    • Analyze the Disk: Choose the Analyze option to scan for partitions. This may help in identifying the VeraCrypt volume if it still exists in a recoverable state[2][5].
  3. Mount the Volume:
    • If TestDisk successfully identifies the VeraCrypt volume, try to mount it using VeraCrypt with your password. If it mounts successfully, you can access your files directly.
    • If mounting fails, you may need to restore the volume header if you have a backup of it. Use the “Restore Volume Header” feature in VeraCrypt[4][5].
  4. Data Recovery Tools:
    • If TestDisk does not recover the volume, consider using data recovery tools like Photorec, EaseUS Data Recovery, or R-Studio. These tools can scan unallocated space for remnants of your encrypted volume[2][7].
    • Run these tools in read-only mode to prevent further data loss.
  5. Check for File System Corruption:
    • If you manage to mount the volume but encounter file system errors, you can attempt to repair it using VeraCrypt’s built-in repair options or by running a file system check on the mounted volume[4][6].
  6. Seek Professional Help:
    • If all else fails and the data is critical, consider contacting a professional data recovery service that specializes in encrypted volumes.
Important Considerations
  • Regularly back up important data and encryption headers to prevent future issues.
  • Encrypted volumes can complicate recovery efforts due to their nature; always proceed with caution when attempting recovery.
By following these steps, you should be able to maximize your chances of recovering your VeraCrypt volume without data loss.
Citations:
[1] https://forum.cgsecurity.org/phpBB3/viewtopic.php?t=7223
[2] https://forum.cgsecurity.org/phpBB3/viewtopic.php?t=8473
[3] https://www.reddit.com/r/VeraCrypt/comments/16tsdfk/veracrypt_volume_recovery/
[4] https://pchelpforum.net/t/i-corrupted-veracrypt-volume-please-help.87764/
[5] https://forum.cgsecurity.org/phpBB3/viewtopic.php?t=8441
[6] https://sourceforge.net/p/veracrypt/discussion/technical/thread/e99fe5b467/
[7] https://sourceforge.net/p/veracrypt/discussion/technical/thread/c179b11ab5/
This is how I “recovered” my VeraCrypt volume:
  1. Open KDE Partition Manager.
  2. Since I recovered other partitions using TestDisk the only remaining space is the VeraCrypt volumne. Right click on it and select “new”. For the filesystem select “UNFORMATTED”. Click ok.
  3. Apply changes and close KDE.
  4. Now select this in the VeraCrypt and do your thing! (enter password etc)
